Old 09-01-2024, 05:32 PM
importsmasher's Avatar
importsmasher importsmasher is offline
Default 73 Formula Dash Bezel Restoration
The dash bezel on my 73 Formula is looking pretty sad. I had to pull it for a different reason, so I'm contemplating trying to make it look better. I'm thinking I could carefully remove as much of the peeling stuff as possible, maybe sand it lightly, and clear coat it.
Has anyone done something similar? Any better suggestions?
Anyone have a nice Formula dash bezel for a car with gauges and no A/C?
Any input is appreciated.
Thanks,
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 09-01-2024, 09:15 PM
I would find a nice correct bezel. There are several on ebay. The woodgrain bezels are a lot cheaper than the T/A ones.
Old 09-01-2024, 10:11 PM
It appears what you have - going by the divided headlight / wiper callouts - is a 70 71 72 model bezel.
I think some of those had differing colors.
It looks really fried where the coating is gone.
73 74 had the headlight / wiper callouts in the same block.
75 and newer will have the RTS emblem in center over steering column.
Any will work just depends how correct you want it.
Any bird espirit up through 81 ,,,, and most formulas up through 78 - use the woodgrain.
Old 09-02-2024, 03:29 PM
Held for Ransom's Avatar
Here is an idea of what a '73-4 bezel looks like and going price for condition.
https://www.ebay.com/itm/355878581041
So long, farewell.
Old 09-02-2024, 03:43 PM
Thanks! I actually just discovered that Phoenix Graphics makes a decal for it, so I ordered that. I'm told the woodgrain may not be correct, but I'm ok with that.
I appreciate all the replies! One day I might seek out a correct piece, but for now this will suffice.
Importsmasher
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
Old 09-02-2024, 04:00 PM
If compressed air or small pressure washer won't get the rest of the peeling off - could try a dishwasher. The hot water might get to it.
You'd want to remove the HL/wiper callouts and the bird emblem.
Oven Cleaner might do it as well.
That's supposedly the go to for removing the yellowed degraded coating from TA bezels.
Same again about removing the plastics first.
They need to come off anyway.
Old 09-02-2024, 05:45 PM
Your current bezel might have a lot of value to the right person. Sell that.. buy the correct one and still have a couple $$ in your pocket.
Old 09-03-2024, 12:27 AM
Formulabruce's Avatar
Any bird Espirit up through 81 ,,,, and most formulas up through 78 - use the woodgrain.
FWIW, Many special edition Esprit used the T/A bezel .
How many fell off their chair on that one?? hehe..
" Long may we DRIVE !"
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 09-03-2024, 01:36 AM
SE Espirit , would that be the Red Yellow Blue Birds ?
Old 09-03-2024, 02:03 AM
Yes Sir!
Old 09-03-2024, 12:22 PM
I've noticed that every bezel I've seen online has the cutout in the lower right corner for power windows or door locks or rear defrost or something. Mine does not. It has an indentation there, but no opening. Did later cars all have the opening, and maybe used a block off plate? Or did only cars with relevant options have the cutout?
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
Old 09-03-2024, 12:37 PM
bhill86's Avatar
bhill86 bhill86 is offline
I don’t know the answer to that but wondered something similar. I have a bezel presumably from an 80 or 81 based on the round turn signal indicators. It lacks even the indentation in that area and is blocked off solid. Except for a hole someone drilled in it. I had a small lamp housing I put in the hole to fill it.
Too bad this isn’t what you needed, it is for sale.
1977 Trans Am 400/4speed (swap)
Brian
Old 09-03-2024, 01:51 PM
The opening was for accessories, door lock and/or defog. No filler like Trans Am's had.
I have an extra of that style, I just don't know what I would charge for it. Better of the two, I'm keeping.
ID:	639451   Click image for larger version
ID:	639452   Click image for larger version
ID:	639453   Click image for larger version
So long, farewell.
Old 09-03-2024, 02:02 PM
bhill86's Avatar
Some appear to have the opening
ID:	639455   Click image for larger version
Brian
Old 09-03-2024, 02:11 PM
Thanks for all the information! As stated above, I have a new decal on its way from Phoenix Graphics, but thanks to this thread I now know what I would need for my car should I decide to make it more correct.
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
The Following User Says Thank You to importsmasher For This Useful Post:
Old 09-03-2024, 02:17 PM
On the woodies , maybe just the ones that actually were going in cars that were getting dash switch options got the separate accessory plate.
I never paid attention to this at all before. just guessing
Old 09-03-2024, 02:27 PM
Keep us posted on results for removing the peeling remnants.
And finished product results.
Old 09-03-2024, 02:29 PM
formula kid formula kid is offline
If you did not get power door locks or rear defrost no cut out just indent.
Old 09-03-2024, 03:09 PM
Pictured in this thread are most of the different styles depending on options ordered.
https://forums.maxperformanceinc.com...d.php?t=773022
So long, farewell.
Old 09-09-2024, 07:22 PM
unruhjonny's Avatar
honestly, by the time you buy and ship the overlay, you will probably be better off replacing the dash insert.
the 1973-1975 pattern is the middle one:
1970 Formula 400
