Does anyone know where I can buy one? Cliff's site does not show one.
revision: I should say a Cliff recommended equivalent. Last edited by DaleO; 09-07-2024 at 08:34 PM. |
What is the carb number?
Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
| The Following User Says Thank You to carbking For This Useful Post: | ||
Call cliff, he has them, sent me one for the q-jet I have. Pretty sure they are a common marine filter though, check a local marina or do some googling but cliff will have them or can tell you where to get them.
| The Following User Says Thank You to 78w72 For This Useful Post: | ||
I got mine at our local napa but I'm sure the boat place up the street sells them too.
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
I7080272 with short filter housing. Thanks
I did a quick google search and all kinds of them popped up on the interwebs.
Many of them look to be some sort of a plastic construction now. Mine is a stainless mesh screen that is cleanable. I saw a couple of those pop up as well. |
Sorry, but newer than any of my documentation; was going to get you a part number.
Jon
I stock them and they come in my Marine carburetor rebuild kits.
You can buy them directly off the website just order this filter and type in "Marine" for the carburetor part number..... https://cliffshighperformance.com/pr...ilter-w-spring
Yes but who knows if they are the same or one is better than another, Cliff's research would remove any questions. I also remember reading here there may be a lighter spring to compliment it.
I don't care for the plastic looking things and wouldn't try one. |
