Old 09-15-2024, 10:01 AM
65gto69's Avatar
65gto69 65gto69 is offline
Default 1965 GTO FIREWALL TAG QUESTION
Not sure if this has been asked before, but I was looking at my firewall tag yesterday and noticed a 3 digit number above the factory code. According to my restoration book, the picture of the firewall tag does not show any 3 digit code above the factory code. I have a 522 code above the BAL###### code. Any idea what this 522 code is. Pic of my firewall tag below.
Also have another question. There is a partial vin number in the trunk gutter on the passenger side or does this represent another number? If it is a partial vin, why does it not match my vin on the vin tag. May car was made in Baltimore and the number in my trunk gutter shows a "Z" for Fremont.
Thanks for your help
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 09-15-2024, 11:30 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Job number
On my Baltimore build ‘65 it stands for the job number.
ID:	639971   Click image for larger version
ID:	639972   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 09-15-2024, 06:06 PM
OG68 OG68 is offline
You'll see those partial 'VIN' numbers on all sheetmetal pieces. They're NOT the VIN but the body style number. If the same part fits a Tempest/LeMans/GTO (which most of them do) it will have the Tempest style number. There may or may not be a Julian week code on the stamp too.
The following is based on conjecture based on my Fremont built '68;
I thought the Z represents the Fremont Fisher Body stamping plant. But having a Z stamping on a Baltimore car makes me wonder. Did other Fisher body plants supply stampings to the various assembly plants?
I have also found the firewall on my car has a Chevelle style number. My guess it is was shared with Tempest
ID:	639992   Click image for larger version
Old 09-21-2024, 11:25 AM
65gto69's Avatar
Thanks for the replies and info. I feel a bit better now.
Mark
Old 09-21-2024, 09:40 PM
GtoFM's Avatar
GtoFM GtoFM is offline
My Pontiac built '64 Lemans/GTO has the "Z" stamp on body panels, FWIW.
Old 09-21-2024, 09:44 PM
So now the question is, what does 'Z' represent?
Old 09-21-2024, 11:10 PM
60sstuff's Avatar
My 1965 GTO Survivor body stampings.
Valance.
Fenders.
Quarters.
Name:	Stamping - 65 Nose Date 9-11-64 (1).jpg
ID:	640323   Click image for larger version
Name:	Stamping - 65 LH Fender,  9 12.jpg
ID:	640324   Click image for larger version
ID:	640325   Click image for larger version
ID:	640326   Click image for larger version
