Old 10-17-2024, 01:02 AM
Sprocket's Avatar
Sprocket Sprocket is offline
Default Parts for Sale at the Pontiac Southern Nationals this weekend
I will have the following parts for sale at the Pontiac Southern Nationals this coming Saturday in Frisco, Texas. Feel free to stop by and buy, buy, buy!
Bilstein Shocks front & rear - B6 Performance '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $300
BMR Suspension Front upper & lower DOM control arms '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $600
BMR Suspension Rear upper DOM control arms & axle housing bushings '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $100
BMR Suspension Rear control arm reinforcement braces '68-'72 GM A-body, '69-'72 GP/Monte Carlo New $100
BMR Suspension Coil springs - front & rear '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in box $200
BMR Suspension Rear sway bar - 1" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $120
UMI Performance Front sway bar - 1.25" solid '64-'72 GM A-body, '69-'72 GP/Monte Carlo Installed and removed $200
Tanks Inc Fuel tank straps & hardware '68-'72 GM A-body, '69-'72 GP/Monte Carlo New in packaging $30
Holley Street HP 950 polished carburetor Universal 4150 square bore Used for engine break in $500
Holley Street Dominator intake manifold w/separated water neck Pontiac 326-455 Used $150
Doug Nash - Warrior Intake manifold w/separated water neck Pontiac 326-455 Used $300
CompCams Ultra Gold aluminum roller rockers - 1.52 ratio Pontiac 326-455 Installed never ran $400
Lunati Retro-fit hydraulic roller lifters Pontiac 326-455 Installed never ran $400
MSD Pro-Billet Ready-to-Run distributor w/vacuum advance Pontiac 326-455 Used for engine break in $400
PowerMaster XS Torque mini starter Pontiac 326-455 Used for engine break in $150
Ames Performance 68-72 GTO Ram Air d-port exhaust manifolds Pontiac 326-455 Used $260
GM 455 crankshaft Pontiac 455 Used $80
GM 12-bolt axle assembly - Eaton posi, 3.42, forged axles '64-'72 GM A-body, '69-'72 GP/Monte Carlo Used <10,000 miles $1,500
'70 GP Model J
467 Butler ported Edelbrock D-ports
Torker II intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers full 3" stainless exhaust
TH400, 3.50 9" CurrieTrac, 245/35-20 Front, 275/35-20 Rear
Old 10-17-2024, 09:24 AM
12 bolt interest. Wondering what this upgraded rear began as.
Is the cast date code in the lower right hand webbing of the center housing, or under the front edge facing the transmission? Thanks.
Old 10-17-2024, 12:35 PM
Sprocket's Avatar
If my memory serves me correctly, this unit was originally a 2.73 peg-leg out of a '71 El Camino. I can check on the code tonight and let you know for sure.
'70 GP Model J
Old 10-17-2024, 09:50 PM
Sprocket's Avatar
The stamped codes on the inside passenger axle tube are: KDC 132 1, which I believe translates to 2.73 open, Buffalo NY, May 12, 1971, first shift.
The casting codes on the lower webbing facing the transmission is GM G2 on the passenger side and 3969278NF on the driver side, which I believe is the code for '70-'72 car 12-bolt center sections.
The cast date code is on the rearward facing passenger side lower web. It was too gunked up and dark outside for me to be able to clearly read it.
'70 GP Model J
