Old 11-08-2024, 12:25 PM
opeliac opeliac is offline
Default Custom oil pan question
I am finally putting my turbo engine together, and it looks like my Langer pan is going to hang too low...What have you guys used with a 7-7 1/4 deep sump that can hold 8+ quarts of oil? I am currently at 11 3/4 crank centerline, so I dont want to raise the engine...If I have to build one, I will, but i'd rather buy something due to time reasons...
A dry sump is looking like my best option, but that is going to change numerous things that have already been sorted out...And will make space become an issue.
Old 11-08-2024, 03:06 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Don't be afraid to reach out to Kevco they are fantastic to deal with.
Go fast, see Elvis!
Old 11-08-2024, 11:22 PM
slowbird's Avatar
slowbird slowbird is offline
I'll have a stef's pan with 2" kickout and 7.75 deep up for sale in few weeks
Old 11-09-2024, 07:42 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
I also have a stef’s pan that is for a BOP belt drive
I’d be willing to part with at a rockstar price.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 11-09-2024, 09:48 AM
John Langer's Avatar
John Langer John Langer is offline
I run my pan with an 11” crank centerline 🤷*♂️
Old 11-09-2024, 01:38 PM
Mine is currently at 4" off the ground with the car sitting an inch higher than I want...This is in a drag & drive car that will see hundreds of road miles...With the engine location, the rear of the sump is about 16" behind the front tire centerline, which will make it a bear to navigate over many road obstacles...
Do you have, or know of anyone that would have a roughed up bottom half? I think if I could shorten the sump, I can make it work, but this pan is absolutely perfect and I dont want to cut it up...
