Old 11-17-2024, 11:36 PM
John Milner's Avatar
John Milner John Milner is offline
Default Removing carb paint
I have a Quadrajet that has been painted with Eastwoods carb renew. Outside of bead blasting, does anyone know of anything that will take the paint off?
Old 11-18-2024, 12:01 AM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Pinesol soak will pretty much strip everything off.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Old 11-18-2024, 12:12 AM
77 TRASHCAN's Avatar
I'm guessing you've tried gerrymandering, and maybe brake fluid?
Shut it off
Shut it off
Old 11-18-2024, 02:20 PM
Thanks for the replies. I haven’t tried anything yet. I guess it is presentable just the way it is but it wasn’t the look I was wanting for the carb. I just didn’t want to make it look worse. I may disassemble it and dip it in pinesol or use some brake fluid and see what happens.
Old 11-18-2024, 02:25 PM
ZeGermanHam's Avatar
Yep, if you decide you want to strip it, you'll definitely need to fully disassemble and rebuild. It would be very easy for paint flakes that come off during stripping to find their way to someplace they shouldn't be.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 11-18-2024, 05:14 PM
The carb cleaner you soak the carb in has in the past removed paint. That is if they haven't changed the formular to make it friendly.
Old 11-18-2024, 05:25 PM
unruhjonny's Avatar
I have seen gasoline remove that stuff.
seriously.
Odds are rattle-can carb cleaner will get most of it off.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 11-18-2024, 06:00 PM
Maybe just leaving it alone and putting the air cleaner on it so you can’t see too much of it would be the best and easiest option.
I mean if it needs to be gone through then yeah I’d probably do whatever was needed to put the proper finish on it.
But if it’s running fine leave it be, at least for me I would. There’s plenty of other things to worry about other than having the exact right finish on a carburetor at this stage of my life.
Old 11-18-2024, 07:55 PM
steve25 steve25 is offline
When I strip plastic or brass models I use fluid for Alcohol lamps and fortunately it come in gallon cans also.
If that Eastwood paint is a Epoxy type your only recourse might be walnut shell blasting.
Old 07-13-2025, 07:18 PM
Just to follow up on this thread, I was able to get the Eastwood carb renew paint off much easier than anticipated. I had some cmc throttle body cleaner on the shelf so I tried some to see what it would do. This will make the carb paint fall off instantly upon spraying the carb. While clearly not perfect, it looks much closer to stock in my opinion, which is what I was wanting.
ID:	654308   Click image for larger version
ID:	654309   Click image for larger version
Old 07-13-2025, 08:21 PM
Looks good Scott!
7041264 (?)
Old 07-13-2025, 09:55 PM
Thanks, Roger. Yes it’s a 7041264, the original one to the 71 GTO I’m working on.
Old 07-15-2025, 04:28 PM
NeighborsComplaint's Avatar
I thought it looked just fine the way it was.
Triple Black 1971 GTO
