Old 12-23-2024, 01:22 PM
John Milner's Avatar
John Milner John Milner is offline
Default 1970 Keylime Green vs 1971 Tropical Lime Paint
I bought a quart of paint locally to paint underneath my trunk lid and around the doors of my 71 GTO. The paint code is 43, Tropical Lime. I gave this information to they guy that mixed my paint and when I went to pick it up, it was marked "43 Citrus Green." I questioned him on that and he said that is what it was named in their system but it is the same mixing formula as Tropical Lime. It appears that Citrus Green was a 1970 GM color used on Camaros and some Chevelles. I think the Pontiac version was named Keylime Green in 1970. Is Keylime Green and Tropical Lime the same color, just named differently? Just looking at pictures, they appear very close and both share the 43 paint code. Thanks
Old 12-23-2024, 02:03 PM
Held for Ransom's Avatar
1970 paint code 43 and 1971 paint code 43 are totally different formulas.
So long, farewell.
Old 12-23-2024, 11:41 PM
VCho455's Avatar
VCho455 VCho455 is offline
This site may help show the differences.
https://tran-zam.com/fhistory/1970Colors.aspx
https://tran-zam.com/fhistory/1971Colors.aspx
You can also click on the galleries for each year and see examples of most of the factory colors.
Old 12-27-2024, 03:56 PM
Thanks everyone. I will be sure to spray a test panel before and compare.
Old 12-27-2024, 05:04 PM
steve v's Avatar
steve v steve v is offline
Did you get a single stage mix or a bc/cc?
Old 12-27-2024, 06:42 PM
I got a single stage mix just to paint around the back side of the doors and under the trunk lid. I will be painting the rest of the car with base/clear when the time comes.
