Old 01-23-2025, 04:52 PM
sdbob sdbob is offline
Default Engine stand rotator questions ,Any ideas?
I have my old ,50 year old engine stand,its home made HD but disassembles. I'm thinking of putting rotating assembly on it. Anyone do this and what did you use? I looked at HF hand winch with worm gears ,I'm not convinced they have quality gears. Thanks.
Old 01-23-2025, 06:09 PM
nytrainer's Avatar
There’s a slack adjuster and s cam from rear truck brakes. Seems involved some but heavy duty.
https://youtu.be/87SOSUjePF8?si=eUx0Y-QKBTfvMdoM
Old 01-23-2025, 07:22 PM
Thank you. He didnt show engine on rotator though. Seemed easy without engine.
Old 01-23-2025, 09:00 PM
nytrainer's Avatar
Beginning of video around 1:45 shows a Ford 7.3 diesel rotated
Old 01-24-2025, 08:55 AM
Ok thank you. I later looked and watched one with Ford power stroke.
Old 01-24-2025, 10:39 AM
Watching one story this morning. He bought those hd truck brake parts at NAPA. Each part,(2 parts) about $20.00. Turning a 1000 lb diesel engine. Thanks.
Old 01-26-2025, 02:47 PM
SRR's Avatar
SRR SRR is offline
I bought this from HF. It has a 454 on it right now with a cast iron intake. I pulled the cover off and packed more grease in it. It will rotate the engine but you have to help it while cranking. Not perfect but a lot easier than a conventional engine stand. It's rated for 1500 lbs...I'll never test that
ID:	646770   Click image for larger version
Name:	engine stand1.jpg
― Calvin Coolidge
Old 01-26-2025, 03:12 PM
Sirrotica's Avatar
Bob. This HF worm gear winch could easily get transformed into an rotator for $35. The winch is rated at 2000# so it ought to turn a 700 # engine over/
https://www.harborfreight.com/2000-l...nch-63755.html
Just a little welding and fabbing, you'll have yourself a manual rotator engine stand.
Link to how one guy fabbed up his homemade rotator: https://www.hotrodders.com/threads/m...otator.523367/
Hit the (see more) tab above the first photo to see all the pictures, and steps.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-27-2025, 04:33 PM
I saw someone use that winch I just thought looks a little light. 2 things, tire shop I hang out at owners wifes family own a large Mack dealership. Thinking talking to him for the brake oarts. When I moved 25 yrs ago I threw out a lot of 'junk' one item was a gear box from a steel over head door perfect size oh well that's life.
