Trying to provide assistance to a gentleman in Germany who is having less than desired performance from a number of aftermarket modifications to a 400 engine in a 1967 Bonneville.
Apparently, his original camshaft failed, and he could not find one in Europe. A mild performance cam was installed. Performance was not consistent with that of the original, so a aftermarket performance intake was installed, which did not help the issue. Next step was to replace the carburetor with an aftermarket; and the car still does not perform even close to as well as he believes it should. He thinks he has lost roughly 100 HP. I suggested returning everything to stock, which he is going to do, IF he can find a stock camshaft. He still has the original intake, and I think I can take care of the carburetor issue, but the camshaft location is out of my area of expertise. Can someone suggest a reliable source for a STOCK Pontiac intake for a 1967 400 4-barrel Bonneville that I can forward to him? Thanks in advance. Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
