Old 03-24-2025, 01:57 PM
joes455 joes455 is offline
Default Spark plug reading
Plugs were run just cruising ,not wot .all plugs looked the same except #1 seems a little rich.Yes I did swap plugs and got same results,also changed #1 intake valve seal.What are your thoughts?
ID:	649354   Click image for larger version
ID:	649355   Click image for larger version
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 03-24-2025, 02:01 PM
I must add ,new engine with 150 miles still running Driven break in oil.Leak down test 4% ,compression 210psi all cylinders.Plugs are autolite 3923,I just put in some ngk fr5 to test
Old 03-24-2025, 04:36 PM
chiphead's Avatar
chiphead chiphead is offline
Have you done the accel/decel runs to seat rings? Just keep it a bit fat and slow timing down for break in. Don't set the tune on kill for the first 1k miles. Just make sure it's not lean or oil fouling, aka keep it between the ditches for awhile. Use 93 octane or higher.
Old 04-22-2025, 07:28 PM
myam myam is offline
What is the best plug gap
Old 04-22-2025, 07:39 PM
64speed's Avatar
64speed 64speed is offline
Yea I broke it in properly. I am 10 miles away from 5000 miles on this build. I always run 93 despite my question about cheaper gas.
The Following User Says Thank You to 64speed For This Useful Post:
Old 04-23-2025, 02:57 AM
Kenth's Avatar
Kenth Kenth is offline
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-23-2025, 02:58 AM
Kenth's Avatar
Are you "Joes455" now?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-23-2025, 06:26 AM
64speed's Avatar
What?
Old 04-23-2025, 07:19 AM
This thread on spark plug reading is "Joes455" thread.
Yours is another thread?
Old 04-23-2025, 07:29 AM
64speed's Avatar
Oh gotcha I’m sorry missed it. I just scrolled down to the bottom and saw the last comment
