Old 03-29-2025, 10:32 AM
pilot737 pilot737 is offline
Default Rally 2 wheel code confusion
I'm trying to understand a wheel code. I have a 67 gto with factory disk brakes and currently rally 1 wheels. My restoration manual states Rally 2 wheels were an option and should be wheel code JA.
On the inside of this wheel, it has the code JK, but on the outside JA. Which one is the correct code? Why the two different codes? And yes, those pictures are the same wheel.
Name:	GTO rally wheel 2.jpg
ID:	649585   Click image for larger version
Name:	GTO rally wheel 1.jpg
Old 03-29-2025, 11:10 AM
Does it have other stampings around the valve stem hole on the outside?
Usually the 'JK' on the inside of the wheel is for the flat part of the wheel .
Old 03-29-2025, 11:24 AM
Flat part of the wheel? What does that mean?
The only code on the outside is "JA" near the valve stem hole (picture attached)
Name:	GTO rally wheel 3.jpg
Old 03-29-2025, 11:26 AM
JA is the wheel ID code.
-Big letter JA or big letter JC were stamped through '67 production up into mid May of '68 when small letter wheel ID codes & external date codes began. The big letter code can be stamped left or right of the valve stem.
-The JK stamped next to the wheel size on the spine of the wheel is the ASAE code for the design of the outer wheel (hoop) design. This will be either JJ or JK for a steel wheel.
Useage:
JA (big letter) '67-68 A-body w disc brakes
JA (small letter & external dates):
very late '68 model A-body disc useage, as well as ALL '69 A-body w drum OR disc brakes.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 03-29-2025, 01:21 PM
burd burd is offline
I saw an article in a POCI mag, they listed all the codes and years and caps for the Rally’s and disco flakes, I got it somewhere.
The Following 2 Users Say Thank You to burd For This Useful Post:
Old 03-29-2025, 01:26 PM
Shiny Shiny is offline
Yes, please
Old 03-29-2025, 01:31 PM
It’s been posted on here before, I have 40 boxes of flooring in front of my stash cabinet, it’ll be a bit before I can get to the magazines.
Old 03-29-2025, 02:43 PM
Here's a forum post linking to an external list, but not to the table/article you described:
https://forums.maxperformanceinc.com...73&postcount=2
