Just wondering if the repops are any good - at $60 I'm highly suspect of the quality.
Take it that its best to get a tested used original or pony up for a NOS?
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
I've bought a few over the years, none of them worked properly but in the end I was able to fix them. Most common issue is the dimmer function.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Hi North. Can you expand upon this a bit, including the fix?
After some additional investigation - I was able to determine the switch was functional.
The repro vacuum line kits have the rubber "lugs" so you can only plug it in one way. These rubber parts had completely split apart and deteriorated, despite the fact that the car has not been driven much and its mostly been sitting for the past 5 years. I ditched these things and used just the nylon barbs. I now have operating headlight doors for the first time ever. Only issue now is the springs don't do a whole lot - I think I need to adjust the doors to provide tension, but I'm not sure how to get at them without dismantling the whole front end.
