Old 06-22-2025, 11:23 AM
BILL BOWMAN1's Avatar
Default Cold case radiator
Any opinions good or bad. Fit and quality most importantly. 64-65 A body in particular.
Thanks.
Old 06-22-2025, 12:31 PM
tooski tooski is offline
May or may not help as this was on my 68 Firebird. I swapped out an oem type aftermarket rad, either 3 or 4 row, I can't remember, for the 2 row Cold Case. It made no difference in the operating temps of my engine. It seems my problems lie elsewhere. However the mounting brackets/flanges on the Cold Case rad moved the rad about 1/2" further away from the support core than the 'oem'. Not a real big problem.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
The Following User Says Thank You to tooski For This Useful Post:
Old 06-22-2025, 12:40 PM
Thanks for your reply. I don’t really have a temperature issue. Mine’s just beat the hell and looks like crap. So it’s more of a cosmetic issue.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
Old 06-22-2025, 01:20 PM
ZeGermanHam's Avatar
Cold Case radiators fit and work well. Recommended.
1998 BMW 328is (track rat)
The Following 3 Users Say Thank You to ZeGermanHam For This Useful Post:
Old 06-22-2025, 01:24 PM
72projectbird's Avatar
I've used them in various 1st and 2nd gen F-Body setups, and they've all been excellent.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-22-2025, 01:58 PM
I have one in my 1964 Le Mans convertible.
Perfect fit, great looking and cools very well.
I have the 17-1/2” core (my car has factory A/C) Severe Duty version with twin 1-1/4” rows of tubes versus the usual 1” tubes. This particular radiator was recommended by Chris Cassperson at Cold Case because of the 421 engine, air conditioning and automatic transmission I’m running.
They only offer this radiator in the 1966/1967 configuration with the inlet on the driver’s side, unlike the 1964/1965 with passenger side inlet. The diagonal flow through the radiator core helps efficiency. So I swapped the 1964 thermostat housing for a 1966 and bought the correct 1966 upper radiator hose. I did modify the steel fan shroud by cutting a new notch for the upper hose and subsequently welding up the original notch on the passenger side.
These cars already have a somewhat limited air intake area for the radiator so they need all the help they can get, especially with the bigger engines.
ID:	653252   Click image for larger version
ID:	653253   Click image for larger version
Old 06-22-2025, 05:35 PM
I had my current radiator modified to the driver side upper hose. Maybe I will contact Cold Case and see if they can do that for me.
Thanks all.
Old 06-23-2025, 04:20 AM
64speed's Avatar
64speed 64speed is offline
I have the same radiator as B-Man in the 15 1/2 version. I think it’s about the best you can do.
Old 06-23-2025, 06:11 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Ditto with the other 64 a body guys. I’ve got a snow cone factory under the hood and looks totally stock.
Old 06-23-2025, 10:46 PM
1965gp 1965gp is offline
I have one in my 70 and 66 GTO’s. Very high quality radiators and work well. I was not happy with their electric fans. The mounting bracket blocked airflow and the fans weren’t enough to keep up. Took their electric fans off and went back to a factory fan clutch and cooled very well.
Old 06-24-2025, 10:38 AM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
There is a cool video this guy did to add spal fans to a cold case on a GTO. I did the exact same thing on my 70 but made my own shroud and it keeps my 535 at 175 degrees all the time.
https://www.youtube.com/watch?v=IeKLbAKBMtc
[SIGPIC]
Steve
The Following User Says Thank You to XLR8STEVE For This Useful Post:
Old 06-24-2025, 06:06 PM
So i drove my beast today.. roughly 10 miles, 99* outside temperature. 535, dry deck, 13.5:1 .
As i pulled back into the garage, the gauge read 205*.. Not bad at all for a old brass radiator, and one crappy little 15”? inch electric fan mounted as a pusher in front of radiator.
It can only get better with some good stuff.
