Old 07-08-2025, 05:37 AM
64speed's Avatar
64speed 64speed is offline
Default Need help not Pontiac.
I have a 2005 Silverado with the digital heat control. I had to replace the control and now I can’t get the temp to sync. Passenger side is hi cold and drivers side is high heat. I did research and all I can find are videos that turn into ads for control heads. I read on another forum about holding the auto button down, unplugging the battery, etc and nothing I have found works. Has anyone actually synced one of these units.
Old 07-08-2025, 07:22 AM
steve25 steve25 is offline
So is this a new control head or a rebuilt one?
I thought that the rebuilt ones come in the needed instructions on how to do the reset.
Old 07-08-2025, 07:26 AM
64speed's Avatar
I’m sorry that wasn’t clear. I went and bought a blower motor resistor to fix it because it’s only the blower that wasn’t working. I replaced the resistor and it still didn’t work. I then replaced the head assuming it just wasn’t getting the signal from the head unit. It still didn’t work. After some trouble shooting I realized the blower motor resistor was DOA so I returned the head unit and defected out the motor resistor. I put the factory head unit back in and the new blower resistor. Now everything works . the drivers side temp even though it’s set to lo it is blowing warm. The passenger side is fine.
Old 07-08-2025, 10:13 AM
had similar issue with a 2010 Traverse...spent tons chasing it at the stealership to no avail...eventually gave up
I'll never use dual climate control again...lol
Old 07-08-2025, 01:14 PM
chiphead's Avatar
chiphead chiphead is offline
Have you checked the blend air door motors? I've got a 2004 Silvy and the door motors love to fail and swing over to "hot" and stay there.
Old 07-08-2025, 01:34 PM
64speed's Avatar
You think that would just start with unplugging the control head?
Old 07-08-2025, 01:45 PM
chiphead's Avatar
The air door motors have plastic gears and a potentiometer to indicate position to the controller head. Once the pot wears out/gets dirty, the motor drives into the stop and strips the gears. Sometimes it will go back to "cold" if the control head is set to cold and the truck is key cycled with the door open. After awhile it will fail back to "hot". You'll also hear some clicking/thumping noises under the dash as the motor malfunctions.
For awhile there in the summer, I'd be driving and the driver's side would go to HOT. I'd stop at a stop sign, turn the truck OFF, open the door, close the door and restart truck. The AC would blow cold again for some period of time.
The fix is to replace the blend air door motor. There are diagnostic procedures on line to confirm the motors work.
Old 07-08-2025, 02:18 PM
OG68 OG68 is offline
The passenger side blend motor froze in the hot position on my wife's 07 SRX driver. Going rate to replace it was about $1500 for a $35 part. Due to its location, most of the under dash components would have to be removed for access. There were shade tree methods requiring special tools and required a bit of dexterity which I'm now lacking.
So to cheat, I physically broke the motor away from the housing and used a small wood wedge to position the door arm. Cold in the summer, halfway warm in the winter. Worked great for a couple years until we finally sold the car.
Ironically the drivers side was easy to access. Three screws and it's off. But it still worked.
Old 07-08-2025, 03:38 PM
64speed's Avatar
Come to think of it I did hear some weird clicking for a couple of weeks
Old 07-08-2025, 04:47 PM
64speed's Avatar
It’s not the blend doors. I went out there and if I swap the passenger to heat the drivers side gets cold. The head unit is out of calibration. I disconnected the battery. I got errands to run and then I’ll hook it up when I get home and see where we are at
Old 07-09-2025, 07:25 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I assume you’ve been all over YouTube? There’s a ton of info there to recalibrate
https://youtu.be/grF8aRtgu1I?si=DOwHZaTFXoJGaXuW
Old 07-09-2025, 07:59 AM
64speed's Avatar
I got busy yesterday and didn’t finish but I FINALLY found a YouTube video that wasn’t an ad. I will mess with it this afternoon and report back
Old 07-12-2025, 09:46 AM
64speed's Avatar
Got it. Thanks guys
