Old 07-09-2025, 08:04 AM
BurgundyJudge BurgundyJudge is offline
Default 1108436 vs. 1108435 starters
Other than the part number, what is the difference between the 1108436 starter and the 1108435? I have a ram air III but finding a 1108436 starter is impossible or costs almost as much as my car. Forget about finding a correct date for my car's build. At this point I'm more interested in function than matching component numbers.
Old 07-10-2025, 02:28 PM
Judge273's Avatar
Judge273 Judge273 is offline
I go by the the theory. Get the starter that is reliable…
Mike/Illinois
Old 07-10-2025, 03:41 PM
Kenth's Avatar
Kenth Kenth is online now
IIRC the 436 uses a different solenoid that has metal housing, weaker return spring and a heat shield.
Otherwise the electrical design and specs are the same.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-10-2025, 08:09 PM
unruhjonny's Avatar
My reply was going to be in essence what Kenth shared;
Pretty much the exact same starter, only a different high(er) heat solenoid.
I have done searches looking for suitable solenoids...
Originally Posted by BurgundyJudge View Post
... At this point I'm more interested in function than matching component numbers.
If you're not too worried about numbers or date, that might be understood to be a small departure from the following suggestion:
I have heard only good things about the small bodied starters.
1970 Formula 400
Old 07-11-2025, 08:03 AM
Any luck finding a suitable solenoid?
I had a hot start problem on my 69 Z28. I tried a new starter and a couple of new solenoids, including one claiming to be heavy duty for hot starts. No change. I bought a NOS GM solenoid spring and installed it and that seemed to do the job.
Old 07-11-2025, 10:31 AM
unruhjonny's Avatar
I seemed to hit a brick wall on finding IF GM even made a replacement legitimate solenoid for the original 1114348;
HERE is a link to a recent thread on this subject.
I believe NAPA makes one; (my notes here say) Echlin #UNI STH107
I am unsure if 'Standard' still makes theirs - but I believe that theirs was SS200X
1970 Formula 400
