Old 08-09-2025, 07:10 PM
Redpiston Redpiston is online now
Default Gasket for rear tail light 66 Catalina
Looking for what the group is using to seal rear tail light housings to the body on 66 Catalina. I am contemplating using duct seal and then removing what squishes out. The material does not harden and to my knowledge does not affect paint.
Old 08-09-2025, 09:02 PM
Rachelsdad's Avatar
I don't have a better suggestion for the housing-to-body mounting (considerably different on my '63). Your thought sounds like a reasonable approach to me.
Metro Moulded Parts lists the tail light lens gaskets for the '66, in case this is something useful for you:
https://metrommp.com/tail-light-gask...talina-mp-956/
Not cheap by any stretch, and I have no idea as to how well these fit, but Metro is a reputable company.
GL HTH
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 08-10-2025, 12:04 PM
Yes I saw those. I originally thought they were the body gaskets but realized they were for the lenses. I have a set of NOS tailights and was disappointed they did not come with the gasket installed since it is a tar based type gasket. I also thought about using the material to install the vapor seal on the door panels since it is sticky.
Old 08-10-2025, 12:45 PM
imposter's Avatar
imposter imposter is offline
i beaded black silicone around it and waited till it dried then installed
Old 08-10-2025, 03:24 PM
Rachelsdad's Avatar
Indeed odd that they didn't come with the seals, if NOS.
I was going to suggest either silicone rubber or even form-a-gasket (I don't know that we specifically would want the goo "sticking" the tail lamp to the body of the car vs a well-seated solution which allows for potentially removing the assembly and replacing it - think "plumber's putty").
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
