OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-17-2025, 05:25 PM
jhhagop jhhagop is offline
Default OHC-6 Valve seals
Has anyone replaced valve seals on on this engine. Need advice on where to get the seals and how to install them. I was a auto tech from 1968 to 2016 and never worked on this type of engine. its probably no different than a overhead valve engine so advice would help.
Old 08-17-2025, 06:25 PM
694.1 694.1 is offline
Step one: Remove the cam.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 08-17-2025, 08:15 PM
Jeff Hamlin's Avatar
Thumbs up
VINTON SEALS ARE IMO A MUST.
The intake valves are all that's needed, but some do both.
Old 08-17-2025, 08:16 PM
If you're going deeper than just seals, do your homework on the valve specs.
Old 08-17-2025, 08:18 PM
Actually, you can slip the belt off of the cam pulley & unbolt the cam without too much commotion. Then valve seals would be pretty much the same as any other OHV. You will need a new cam tower gasket & then cam timing is critical, of course. Just make sure that you index the crank ahead of time & get the cam & dist drive where they belong. For me, the hard part would be doing the seals!
7th Firebird
57 Starchief
Old 08-17-2025, 09:46 PM
Thank you all for your advice the factory manual doesn’t show any of what you all suggested it seems like more work than I expected seems like at my age of 77 the whole days work if I’m lucky. The cars smoke a lot when first started then seems to get better as you drive typically valve seals act that way again thank you all
Old 06-08-2026, 01:50 PM
Cammer-6 Cammer-6 is offline
sloppy valve guides will also create this cold start smoke
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
