Old 09-02-2025, 05:05 PM
Verdoro 68's Avatar
Default '72 455 Emissions Decals - Info Needed
I'm working on a repro '72 455 emissions decal and I've uncovered two variants. - The part numbers are 487352 and xx9027. I haven't located a pic with a full number of the second version). An easy way to tell them apart, aside from some text alignment differences, is that 352 decal has .035 plug gap and the 027 has .040.
Does anyone know the application for both and the full part number for the xx9027 decal? Perhaps someone with a master parts catalog?
Thanks!
ID:	656536   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-02-2025, 05:30 PM
65madgoat's Avatar
The bottom decal was from a California sold 455HO fbody car with the .040 gap on it. Love someone to chime in with further info and full part number.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 09-02-2025, 08:05 PM
Held for Ransom's Avatar
489027. Lists engine codes WM, YB, WD and YE.
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 09-02-2025, 09:26 PM
I would think the Unitized 455 HO may have gotten a bigger gap plug?
But why they would not use a different 'pick' letters I don't know? (PL)
Old 09-03-2025, 07:16 PM
Verdoro 68's Avatar
Thanks - so that would be all 455HOs, correct? Any idea what 487352 is used for?
I thought it might be Unitized, too, but the example car doesn't have Unitized ignition. Then maybe I thought California-only but both decals say they cover California emissions at the bottom. Did they change the tune up specs some where throughout the run? If that's the case, it could explain why the decals have the same pick code.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-03-2025, 07:44 PM
RamAirBirds RamAirBirds is offline
It would be 489027....
I have a 72 Lemans Sport Convert with 455 HO.
This is the decal I have. I will try and get a photo of it up. It is near mint and clearly legible.
The Following 2 Users Say Thank You to RamAirBirds For This Useful Post:
Old 09-03-2025, 09:23 PM
When was the build date on the Lemans?
Old 09-03-2025, 10:13 PM
65madgoat's Avatar
Sticker part number 489027 with a points ignition 455HO California f-body and a build date of March 1972 for reference seen here....
Old 09-03-2025, 11:49 PM
Verdoro 68's Avatar
I have enough info to make the one for your car now. The part number was the missing piece. I'll table the 487352 until I get an ask for it.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-04-2025, 06:26 AM
The pick 'PL' is for the 455 HO I think.
At least the build sheets I have seen show 'PL' but don't know which number they have.
One other thing I saw was some had 'PL' plus another 2 letter code? Possibly for the other number?
(also may have been for a Firebird)
Old 09-04-2025, 06:42 AM
JohnTa1
Build date on the 72 Lemans Sport is 04A
The Following User Says Thank You to RamAirBirds For This Useful Post:
Old 09-14-2025, 12:18 AM
Verdoro 68's Avatar
Here's the latest draft of the '72 PL decal I'm working on for 65madgoat. I think it's pretty close. The quality might be a little degraded due to the low res images in the forum.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 09-14-2025, 09:30 AM
Maybe see if you can get the illustrations a little better.
So long, farewell.
Old 09-18-2025, 06:14 PM
necdb3's Avatar
necdb3 necdb3 is offline
Dave at ECS made these several years ago for NJSTEVE and myself. Around 2006-2007. They where perfect!
Old 09-18-2025, 06:39 PM
Verdoro 68's Avatar
I beefed up the line weight of the illustrations as Mike suggested and sent these off to print. I should have them sometime next week. I'm having them done in laminated weatherproof vinyl, similar to what I had the '71 decals done in. I'll post some pics when I get them.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 09-26-2025, 05:11 PM
Verdoro 68's Avatar
'72 decals have arrived!
ID:	657776   Click image for larger version
ID:	657777   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
