Old 09-04-2025, 03:11 PM
al1950 al1950 is offline
Default 66 Grand prix wiper blades
Hi Pontiac People
I need help to find wiper blades for my 66 GP. I have looked everwhere, no luck?
Allan
Old 09-04-2025, 03:22 PM
Jonsie Jonsie is offline
Maybe Rock Auto?
Old 09-05-2025, 09:02 AM
mgarblik mgarblik is offline
I just looked in the Ames catalog. I see they don't have a listing for 65-66 GP's specifically. They also have a note: except GP. What is different on a GP those years with the wipers than a Catalina, Executive, Star Chief, Bonneville, Ventura? I would think all B body wipers would be the same in 65-66 other than possibly convertibles?
Old 09-05-2025, 09:10 AM
Rock Auto does show a 15" Trico Classic blade that physically looks correct if the length is correct. about $25.00 each.
Old 09-05-2025, 09:18 AM
thanks. I also called Ames, they said GP 17inch not available. My originals are 17inch.
Old 09-05-2025, 08:35 PM
stevep's Avatar
stevep stevep is offline
They are actually 17.5"
Old 09-05-2025, 10:23 PM
694.1 694.1 is offline
Olds Starfire would be the same. maybe the Fusic catalog?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 09-06-2025, 01:40 AM
Carl S Carl S is offline
I bought the Trico Classic 33-150 blades. The appearance and fit is identical to the original blades. I can't recall if I got them from Rock Auto or off Amazon.
1966 Strato Chief 427 4 Speed 45,000 miles
1966 Grande Parisienne 396 4 Speed Factory Air (1 of 23)
Old 09-06-2025, 06:28 AM
Those are great looking blades but are 15" long. For some reason they don't make 17" models that look like that. I am a little puzzled that a GP would take different blades than all the other 65-66 full size Pontiacs? Is the windshield taller or have other differences? Do all GP's those years go back to using the parallel style wiper system rather than the articulating style of the other full size cars? Just seems a little weird. Always trying to learn new things. I saw a couple sets of 17" blades on E-bay for crazy prices like $300.00 for a used pair. That's nuts !
Old 09-06-2025, 08:24 AM
thanks for help, these are the strangest design I have seen, they have 2 arms from the post to the end where the blades attach and a very strange looking attachment head that connects both arms to the blade . i looked at all recommended one s to try , but come up with nothing. even if I went with 15 inch( which would be less effective and unsightly on this big old beast), the head attachment on the trico is different from mine and appears it would not fit.
Old 09-06-2025, 08:27 AM
Kenth's Avatar
Kenth Kenth is offline
Std wiper blades for 1966 GP are the 15" TRICO 33-150.
With overlap 2-speed wipers use the 18" TRICO 33-183.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-06-2025, 12:14 PM
HTH
That should be good information for him. So his car has the overlapping 2-speed wipers. Pontiac called the articulating wiper arms. Sounds like the 18" blades will work. I would like to see a pic or 2 of the attachment situation which is the last part of the puzzle.
Old 09-06-2025, 12:24 PM
I can send photos, but do not know how to do it on this site, help.
Old 09-06-2025, 12:48 PM
Scroll down below where you type in your replies to attachments. Then you can choose the pics to post. They are very specific about which file extensions you can post and file size. No high resolution stuff will post. Download and post. 5 pic maximum. You have to do them 1 at a time. Not the most user friendly site for pics.
Old 09-06-2025, 01:12 PM
OK, finally got off my lazy butt and got the 66 factory service manual out. Mystery solved. Those wiper blades are NOT serviceable. They are serviced by refills only. Almost no manufacturer makes refills anymore, but there are some out there. They don't list the size you need but I am guessing 17, 17.5 or 18" Measure an old one if it's still in there. If the arm, articulating joint or link are damaged, you need the whole arm assembly. Franks Pontiac parts would be a good source. Steve Barcaks Pontiac Heaven would be another. Pontiac built over 500,000 cars in 1966 that used those arms. You should be able to find them if needed. Hope this helps.
ID:	656773   Click image for larger version
Old 09-06-2025, 01:18 PM
These refills should work. You could shorten them if necessary.
https://www.oerparts.com/product/*17528f.html
Old 09-06-2025, 02:01 PM
great help Sir, I attached photos, those are some wild designed wiper arm systems. I will order the refills per your link. thanks so much for your expert help. Allan
ID:	656786   Click image for larger version
ID:	656787   Click image for larger version
ID:	656788   Click image for larger version
ID:	656789   Click image for larger version
Old 09-06-2025, 02:25 PM
Kenth's Avatar
These would be a direct fit:
https://www.rockauto.com/en/moreinfo...t=8852&jsn=338
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 09-07-2025, 01:53 AM
Right, I forgot. My car is a Grande Parisienne (Canadian) and has the same setup as your 1 speed wiper cars in the US. Your 2 speed wiper cars use a different length. I'm sorry for confusing the issue.
Old 09-16-2025, 05:02 PM
Default thanks
thanks so much to all Pontiac friends, I ordered the 18 inch refills from classic ind and after a challenging installation following your helpful instructions, I now have new wipers and they look and perform perfectly, so grateful to all.
thanks Allan
