Old 09-06-2025, 06:07 PM
sd455hota's Avatar
sd455hota sd455hota is offline
Default RA4 block 9792506
I came across this block and thought I would post here, before I do something else with it, in case someone has the car it came from?
Emailed response his best [email protected]
Old 09-11-2025, 10:59 PM
I ran Google search as hardtop and convertible , and got 0 hits .
Could still be out there though.
Old 09-12-2025, 02:20 AM
Scott Thelander's Avatar
clean clean stamping
Old 09-12-2025, 07:21 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Do all the 69 RA4 blocks have the last 4 digits ground and stamped?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 09-12-2025, 07:38 PM
Some have the last 4 ground off
Some have them all ground off
If I'm remembering right , only 68 model year blocks were full As-Cast numbers.
SR's might could be anything amongst those mixtures.
Old 09-15-2025, 12:06 AM
Good info
Old 09-15-2025, 01:02 PM
Thank you. A friend of mine is doing some work on a RA4 69 GTO. The last 4 are ground off and stamped. Also the EUN has a digit thats stamped higher than the rest and the partial vin is next to the EUN. All new to my eyes.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 09-15-2025, 03:33 PM
turbo69bird's Avatar
Shouldn’t there be one more digit On that vin after the P?
Scratch that. Just realized my vin is incorrect on my reg on one of my cars , lol. Well at least I found that issue.
960 HP @ 11 psi, 9.70 at 146.
Old 09-16-2025, 06:32 PM
Sounds like you’ll be taking a ride to the DMV
Old 09-16-2025, 08:06 PM
The whole EUN should look more hand stamped than machine stamped.
Fremont and Atlanta (1969) put the VINs in the upper zone.
Old 09-17-2025, 10:04 AM
Thanks for the info!!
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
