Old 09-07-2025, 09:49 PM
JUDGE3 JUDGE3 is offline
Default Turbo charge kit for Pontiac
Wanted one of these kits from HO back then couldn't afford it as a youngster. so cool!
ID:	656824   Click image for larger version
Old 09-07-2025, 11:15 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Very cool, compressor looks tiny for a 350ci etc but even more interesting is the passenger pipe runs under the front of the block.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 09-08-2025, 01:10 AM
Joe's Garage Joe's Garage is offline
Default HO Racing's TurboForce kits were GREAT!!
Light-years ahead of any competition at the time.
They were designed to be installed on pure stock engines, so their turbo was sized accordingly.
We've still got one complete kit on-the-shelf and we are the current caretakers of the LAST Pontiac Craig Hendrickson ever owned.
It's a 1976 Esprit with a 400 and a TurboForce kit installed.
Here's some info about the Esprit from Wallace Racing:
http://www.wallaceracing.com/TurboForce.html
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 09-09-2025, 01:49 PM
Pontiac Performance Author
If I recall correctly, the Rajay 301E turbo had a 57 mm inducer. We adjusted the exhaust housing A/R depending on the engine size-1.7 for 350, 1.8 for400, and 1.3 for 455. An unrestricted 301e was good for about 500 HP.
Old 09-10-2025, 08:35 AM
73 TRANSAM 73 TRANSAM is offline
I think there was a typo on the AR for the 455. Shouldn't it be bigger for the 455 for less back pressure?
Old 09-10-2025, 09:42 AM
The 1.3 A/R housing was noticeably larger than the .7 housings which is why we used then on the 455s.
Old 09-10-2025, 11:57 PM
I didn't mean to disrespect you. But it looks like you added the 1 in front of the .7& .8. Thats probably why I got confused. Thanks.
Old 09-12-2025, 07:27 PM
T/A 3. no disrespect taken. In fact, on my second post I added an edit about the typo, but it didn't take.
Old 09-12-2025, 07:36 PM
73 TRANSAM. T/A 3.was another typo. so sorry. I hate getting names wrong.
Old 09-12-2025, 10:21 PM
No problem. I hope I didn't came out rude as that's not my intent. I owned your books and have a very high respect for you.
Old 09-13-2025, 04:39 PM
Joe-Touring Joe-Touring is offline
67 LeMans, 326, M20, 3.31 12 Bolt
The Following User Says Thank You to Joe-Touring For This Useful Post:
Old 09-13-2025, 04:40 PM
From a post on this forum a few years back, not sure where. Hope everyone enjoys!
Old 09-13-2025, 10:04 PM
Maxthe222 Maxthe222 is offline
I recently just picked up one of these kits leftover from one of the Macho T/A's, mostly incomplete but I've got the air cleaner, the RayJay 301E, and other random parts for it. Getting one of those water gallery covers made for it, and might install it on my VSE Fire Am or maaaaaaaaybe my Macho
1987 GTA L98
1981 Y85
1979 Y84/WS6/Z49
1979 VSE F/A W72/4+1
1978 Macho #46
1978 W50/L80
1972 WS4 Lucerne Blue
1971 W66/M20/L78
Old 09-14-2025, 04:27 PM
Rachelsdad's Avatar
If only these were available (perhaps they were?) for my anemic 305 4bbl in my '82 SE...
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
POCI #3596 (since 1978)
Old 09-14-2025, 04:32 PM
Rachelsdad's Avatar
...or better, for my preference of supercharger over turbocharger, a Paxton centrifugal unit...though where either of those would fit under the hood of the '82 I haven't a clue; it's pretty crowded under there (particularly with AC)...
Lewis
Lewis Rosenthal
'56 Safari
'82 Firebird SE
Old 09-14-2025, 06:00 PM
turbo69bird's Avatar
Huh I always thought these were draw through set up’s.
In the 70s draw through a were very popular on go fast boats , but they’d puddle fuel in the intake and caused many fires.
They did it so often that they hit a bad name and go fast guys today still refuse to adopt turbos for the most part
Blow through was a far better system but back then it was like voodoo to set his. Carb for blow through unless the whole carb was boxed.
The turbos of the day were almost always sized too small creating too much heat. 1 the gas crunch was on and efficiency was pretty important . And 2 the carbs were typically sourced from airplanes and they were more “turbo normalized” vs boosted. Meaning they were made to make the thin air up higher more normal than ti be a power adder.
960 HP @ 11 psi, 9.70 at 146.
Old 09-15-2025, 01:36 AM
Rachelsdad:
We did a prototype for the carbureted 3rd gen and it worked really well. Only engine mod (other than turbo kit) was the use of the cop car Z28 clutch fan and shroud. The Chevy crowd showed no interest in it. I guess the stigma of a kit coming from a PONTIAC co. was a deal breaker.
Looking at the "bonnets" from the old articles, the first bonnet pictured is the first design based on the prototype bonnet. the next bonnet pictured was the second design with a diffusion section added at the inlet side and an anti-surge valve. The third design was the one in the full kit picture . It featured a contoured underside (like that of a stock air cleaner) and was developed with the aid of our flow bench and pressure probes. Also note the increased size of the diffuser section and elimination of the anti-surge valve. A fourth design was modified for use with right angle inlet Q-jets, and Holley linkage.
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 09-15-2025, 02:01 AM
We had second gen Camaro kits also. a DUD.
Old 09-17-2025, 09:40 AM
78w72 78w72 is offline
Would be cool if someone could make these turbo kits today... bet they would sell as good or better than they did back then.
Hint hint
Old 09-19-2025, 06:31 PM
77 TRASHCAN's Avatar
I was at the 2010 GTO Nationals in Wichita. Craig was a speaker there. He talked a lot about this turbo kit. He said there was a lot involved in getting the "hat" to do it's job.
THanks Joe!!!
I too could not afford one of those kits, back then. They'd likely be $5000.00 now or more...
Shut it off
Shut it off
