Old 09-09-2025, 10:09 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Default old (late 1990's era) Crane solid roller lifter interchange
Question gents, on the older Crane solid roller lifters (Pontiac of course) dimensionally regarding same depth so same push rod length, what are the current brands or ones if ya know are the same installed spec ?
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 09-09-2025, 12:07 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I would contact Brad at Bam Lifters, he worked for them and would probably know that question.
Not related to rockers but I run his lifters with no issues.
Dave Polichena
The Following User Says Thank You to Dave Polichena For This Useful Post:
Old 09-09-2025, 05:03 PM
Dragncar Dragncar is offline
Those BAM DLC lifters have proven to be very durable.
And IMO I would not waste my time with hyd rollers after all their problems. Just go solid with BAMs. You do not need to check lash all the time if you use good parts.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 09-10-2025, 11:17 AM
I just need one pair to re-complete my Crane set not a whole set kind had to buy today a local deal on Ebay for a link bar pair of Comp well see , I called Howards but they are out of stock would have been half the price of the Comp oh well , I need my stuff going soon can't wait. Thank for the feedback
Old 09-10-2025, 02:14 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I have a box of old Crane stuff a post a picture of what I have .... I'm not really clear what your looking for? One pair on Crane lifters??
Go fast, see Elvis!
Old 09-10-2025, 02:47 PM
One pair of Crane solid roller BUT I just pulled the plug on Ebay for one pair on some Comp ones that showed to be local in Arlington! dang it forgot to ask you
Old 09-10-2025, 02:48 PM
Paul I hit cancel on my Buy it Now order try to Stop it from shipping sent message
Old 09-10-2025, 05:20 PM
PAUL K's Avatar
Happens all the time. I think folks put my number under "free tech advice" rather than "ready to checkout"
These are either late Crane or early BAM. They have about forty passes and dyno time on them. I also have a box of old Crane tall body offset lifters we used to run until Crower made them for a Pontiac.
Go fast, see Elvis!
Old 09-11-2025, 02:43 PM
Are coming to XRP Sunday or I can swing by sometime and bring what I have to compare if thats cool. My Ebay order cancel worked and was refunded
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 09-12-2025, 02:31 PM
OK, years ago I bought a used set of Comp SR lifters from Ace at PPR. They were in his dads car and had a fair amount of use on them. BUT, one set had a small crack in a lifter body. What I ended up doing was buying one pair of the cheap Butler SR lifters and running that pair on # 1 cylinder. That pair had a different length pushrod with a different wall thickness. It ran fine for over a decade, the engine never knew the difference.
