Old 09-11-2025, 07:30 PM
67Lemons 67Lemons is offline
Default Need a new Quadrajet air horn
So I’m a dummy, I was rushing swapping out an accelator pump and snapped the outer ear for the accelerator pump arm. It’s the original for the car, carb# is 7042263.
I’m looking to grab an air horn from another carb to use on mine, what year or carb number air horns work?
1972 GTO
Old 09-11-2025, 08:37 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Talk to Ray Klemm. Many times that type of breakage can be repaired.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 09-12-2025, 06:07 AM
Pav8427 Pav8427 is offline
Can save that by tapping back piece for 6-32 ? Or 8-32.
Run a allen head capscrew w/ washer and blue loctite.
Old 09-12-2025, 06:11 AM
If it can be saved that would be great, I’m not sure how though?
ID:	657009   Click image for larger version
1972 GTO
Old 09-12-2025, 06:33 AM
Pull the roll pin out and tap for a bolt the same size as roll pin. When reassembling, tighten up till snug and back off a small amout. Let loctite set up over night.
The Following User Says Thank You to Pav8427 For This Useful Post:
Old 09-12-2025, 07:27 AM
steve25 steve25 is offline
Come on gang this isn’t that hard a fix.
At pain in the ass times like this I ask myself what if I where part of the crew of Apollo 13 , what could I come up with?
Make a small steel L bracket that gets captured down by that carb mounting bolt.
Shouldn’t take more the a hour or so if you have a jig saw with a metal blade and few drill bits .
But make an accurate card board template first .
Remember that when you bend that flat steel into a L shape you will loose some length, probably like 5/16 of a inch worth so make it longer then your template by a good amount and cut it back once bent .
The last thing you should do is drill out the carb mounting bolt hole.
When you drill the hole to pass the carb bolt thru make it a little bigger by 3/32 or so to give you some adjustability in setting the side clearance to the pump arm.
Use a flat washer under that carb hold down bolts head so it does not spin the bracket you made when you tighten it up.
Also make sure if you use this washer that the carb bolt is still long enough to not strip out on you due to only engaging 2 or 3 threads in the intake.
Make sure also that this steel bracket is no taller then what the stock one was so that you have no air cleaner base clearance issues.
Old 09-12-2025, 07:32 AM
gtobob67 gtobob67 is offline
I've used this before and it does work.
https://quadrajetparts.com/quadrajet...air-p-825.html
The Following User Says Thank You to gtobob67 For This Useful Post:
Old 09-12-2025, 07:46 AM
Formulas's Avatar
Formulas Formulas is offline
When i bought one of my Formulas the original carb was already broken in this manner and had a screw in it and was working as received up till i replaced the carb.
It was a common small machine screw
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
The Following User Says Thank You to Formulas For This Useful Post:
Old 09-12-2025, 08:06 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I fixed one years ago, JB welded and small machine screw if I remember correctly.
Otherwise, what’s the number of your air horn, I can look for one
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 09-12-2025, 04:07 PM
Awesome ideas, thanks everyone!
1972 GTO
Old 09-12-2025, 05:00 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Yep, I use this on my carb and it works fine. I still have the broken off ear piece, and someday I plan to have it professionally repaired so it looks like it never happened, as it is a somewhat special carb (17059263 for '79 W72's), but for functionality, the Quadrajetparts.com repair kit works fine.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 09-13-2025, 02:57 PM
glhs#116's Avatar
glhs#116 glhs#116 is offline
My carb had that happen more than a decade ago. JB Weld was my friend
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 09-14-2025, 08:10 AM
For now JB Weld to the rescue, I’ll figure out my plan moving forward over the winter but want to burn as much fuel as possible before the snow fly’s.
1972 GTO
The Following 2 Users Say Thank You to 67Lemons For This Useful Post:
Old 09-14-2025, 10:21 AM
Definitely enjoy the car as much as possible!
Old 09-14-2025, 01:12 PM
zippy's Avatar
zippy zippy is offline
This is a thing. common to break that tab
https://quadrajetpower.com/accelerat...ng-repair-pin/
Dan Pesonen
"If it ain't broke, modify somethin till it is"
The Following User Says Thank You to zippy For This Useful Post:
