Old 09-14-2025, 11:36 PM
itmajors itmajors is offline
Default 1963 Grand Prix - Brake lights staying on all the time...
Hello everyone..
I have an electrical problem on my 1963 grand prix. The battery on my car was going dead after a few hours if left it connected so I always disconnected with a battery quick disconnect pole adapter, a few days ago I noticed that my brake lights were on all the time, so I replaced the original brake light switch on the brake pedal that did not fix it... I tested both cables to the stitch have ground signal..
Any ideas what to test next? Has anyone had this problem?
Thank you and have a great week!
Old 09-15-2025, 06:40 PM
stevep's Avatar
stevep stevep is offline
Is there power on both sides of the switch with the button fully depressed?
Old 09-18-2025, 07:51 PM
Thank you SteveP
No power on either one both are ground, it may have been like that since I bought the car... just started driving it a couple of months ago after fixing everything. Maybe I have the wrong cables connected to the switch
63 Grand Prix - 455 Buick Stage 1 - TH400r - B&M Shifter - 🙂 Rear tires don't last more than 2 months 😉
Old 09-18-2025, 09:52 PM
If 1963 is the same as 1964 there are 2 single WHITE plugs. One has a PURPLE wire and one has a WHITE wire.
Old 09-18-2025, 11:01 PM
Thank you goat racer... My has the 2 white plugs and one white and one black both Negative but somehow the brake lights are on... I was looking online and appears that the white wire goes to the turn signal switch. I am not sure what is going on... I am going to look for the purple wire under my dash it maybe connected to another power source
Thanks again
Old 09-19-2025, 05:49 AM
johnta1 johnta1 is online now
Is it actually brake light, bright light?
Or tail light?
What happens when brake pedal is pushed?
Turn signal on?
Take a brake light bulb out then both and see what happens?
Also take the stop light fuse out and see what happens?
