Old 09-15-2025, 10:45 AM
TheCeleryStalker TheCeleryStalker is offline
Default Name this Control Panel
I am getting around to troubleshooting my AC/Heat and have a question.
Can anyone identify this Vintage Air (supposedly) control panel?
It seems the controls are reversed. Heat turns on the AC and AC turns on the Heat. I have been able to get the heat fixed, by replacing a bad and disconnected valve, but I cant find this particular control panel associated with Vintage Air.
Name:	Control Panel.jpg
Old 09-15-2025, 10:12 PM
Figured it out. Apparently, this IS the correct sure fit panel for cars with factory air.
Old 09-16-2025, 10:13 AM
pfilean's Avatar
pfilean pfilean is offline
Looks like it has usual Vintage Air control knob functions just adapted to a slide lever configuration.
Old 09-16-2025, 10:17 AM
The weird part is that when I look at the panel for 68 Firebird on the VA site, the control positions are reversed. The panel on the VA site has Hot on the Left and Cold on the right, for instance. This is not how my panel looks, but it IS how it functions. I have yet to find a picture of VA 3 lever panel with the control positions like this one. I think it may be easier to just see if i can order the panel that corresponds to how my levers work rather than trying to reconfig the levers on this one.
Old 09-17-2025, 03:59 AM
Squidward's Avatar
Is it possible that the cal was not done correctly? I have a Classic Auto Air system, and it basically works the same: enter cal mode, and put sliders in the appropriate position as called out in the cal procedure, to remember the resistance setting on the 10k ohm sliders.
Consider starting there. Maybe the installer taught it wrong?
Interesting enough, your current control panel is how mine is set up: cold left, hot right. Dash vent position is all the way left. My system took the factory air control head and converted it to fly by wire, so it looks factory.
If you were feeling adventurous, you could possibly reverse the slide resistors upside down so that the max/min resistance sides are swapped. Then your functionality would likely match your controls.
Old 09-17-2025, 07:03 AM
Thanks! I'll give the resistors a try. Honestly, it works fine, the OCD in me just cant stand the mislabelling.
Old 09-18-2025, 06:04 AM
Squidward's Avatar
Fer sure!
