Old 09-18-2025, 09:04 PM
sdbob sdbob is offline
Default A good tool with light to check points when opening.
I'm looking for a good light to see when points open. I don't have one and don't want to buy junk.
Old 09-18-2025, 09:08 PM
Drag Star Le Mans's Avatar
Good old dwell meter is all I use. Not sure of anything else on the market?
DragStarLeMans
Old 09-18-2025, 09:17 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
If that is all you want it for, junk will do.
Old 09-18-2025, 10:12 PM
OG68 OG68 is offline
ohm meter with ignition off
Old 09-18-2025, 11:14 PM
VCho455's Avatar
VCho455 VCho455 is offline
Check Craigslist people are basically giving timing lights away these days.
Old 09-19-2025, 04:08 AM
Ah I got baited in and bit the hook...
DragStarLeMans
Old 09-19-2025, 08:30 AM
mgarblik mgarblik is offline
I have mentioned this before, but IMO, you just can't beat a SUN 7501 inductive timing light. Out of production for over 20 years, you still see plenty of them on E-bay. I got mine for my 16th birthday and I am 68. I have used it on thousands of engines. Still super bright, high quality chrome plated metal body. Rubber nose in case you touch a fan blade. (I have several times). Inductive lead is high quality as well. See nice used ones on E-bay for as little as $25.00 NOS ones on E-Bay for $75.00 or so. Works fine with all MSD style ignition systems. No dial back feature, just a basic timing light.
Old 09-19-2025, 09:17 AM
As did I lol.
Old 09-19-2025, 10:35 AM
Ok thanks guys. I was watching RoadWorthy rescues. He needed to ck if he had spark that little light blinked when points opened. Never used one. Thought simple easy.
Old 09-19-2025, 12:42 PM
Like I answered before, a cheap (under $3 at Harbor Freight) test lamp will tell you when the points are open.
That assumes that the rest of the ignition system is working, the key is on and a battery is installed.
Will it tell you if spark is happening? No.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 09-19-2025, 03:38 PM
Misunderstood that one and can't delete it. Sorry. Carry on.
Old 09-19-2025, 06:24 PM
77 TRASHCAN's Avatar
A magnetic base doo-dab to hold your cel phone and one of the magnetic base lights would allow one to record the event...
I watch most of his stuff. He's lost some weight. I have not seen any explanation for it on his videos. I don't subscribe to his paid for shows, though...
I have learned a little from him, not a lot. There's been times where I wish I was there, I could have helped solve a problem...
Shut it off
Shut it off
Old 09-20-2025, 03:13 AM
OK so you're coming clean about working on lightening werlers and sparkalators? Well this is a whole different ball game then. Good luck on your search.
DragStarLeMans
