Old 09-25-2025, 09:18 PM
Ronj1969 Ronj1969 is offline
Default Best throw out Bearing
I’m putting a 67 Muncie in my 1977 Trans Am. What is the best most Durable do it once and forget about it throw out Bearing
Old 09-25-2025, 09:41 PM
694.1 694.1 is offline
Buy American & keep your foot off the peddle!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 09-25-2025, 11:02 PM
As you can tell I’ve done this before where it basically crumbled onto the ground in pieces. lesson learned to not get it at oriellys .
Old 09-26-2025, 10:15 AM
Joe-Touring Joe-Touring is offline
I like Timken or SK. There’s 3 different bearing lengths, make sure you match yours up.
I :believe: I used the middle size for my 4 speed swap
Mentioned in post 6 of this thread:
https://forums.maxperformanceinc.com...d.php?t=726449
67 LeMans, 326, M20, 3.31 12 Bolt
Old 09-26-2025, 10:43 AM
mgarblik mgarblik is offline
I would add Bower/BCA and NDH, (New Departure Hyatt) to the list of good ones. But may be hard to source those. Finding USA made ones may be difficult as well. I try to stay away from the bearings that have a plastic sleeve/collar and also a plastic cage for the balls in this application. Finding quality parts is more and more difficult every day.
Old 09-26-2025, 10:56 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
NDH -first I heard of Hyatt Bearing was pulling apart a stock 65 Chevelle 12 bolt this month. Pinion , carrier and axle bearings all Hyatt.
Skip Fix
