Old 09-28-2025, 12:33 PM
lintmann lintmann is offline
Default June 70 Spoiler has stuff rolling around inside it.
So I mounted my original spoiler today and noticed some hard bits rolling around inside it. I assume its old bits of adhesive from the three underside panels. It's a bit embarrassing so was wondering if anyone knows of a good easy fix for this or if I'll have to remove the panels to clean it all out?
Your thoughts are appreciated.
Old 09-28-2025, 12:45 PM
Shiny Shiny is offline
When would you notice this?
Inject some foam?
Old 09-28-2025, 08:48 PM
steve v's Avatar
steve v steve v is offline
You don't want to separate the big parts if you don't have to. I had to repair a spoiler years ago that the pedestals had been broken off & the upper / lower sections had separated. IIRC there are several internal ribs running front to back to help strengthen the flat panels.
You could drill a small hole (maybe 3/8"-1/2" ?) in a hidden location underneath towards one end & then try your luck at trying to shake them out of that hole. If they do come out repairing the small hole shouldn't be a bad job. Good luck!
The Following User Says Thank You to steve v For This Useful Post:
Old 09-28-2025, 10:19 PM
Shiny, I noticed it while man handling it and you can hear some when opening the trunk.
Steve V, that's not a bad idea. Do you remember if the insides are open between each section or do the pedestals separate them? Just wondering if one 3/8 hole at one end of the spoiler would do it or if I would have to drill into each panel...
The Following User Says Thank You to lintmann For This Useful Post:
Old 09-29-2025, 08:15 AM
steve v's Avatar
It is open, the bottom part is one piece with indentations where the pedestals bolt to it from the inside.
Old 09-29-2025, 09:49 AM
Maybe a stud finder could locate the internal ribs and guide and help you isolate the noise to a single internal cavity???
Drilling sounds painful but I understand why you want the noise gone.
Old 09-29-2025, 10:42 PM
The stud finder sounds like a good idea so I'll try that. I guess it's not the end of the world if I leave it but the car is going in for paint soon so now would be the time to deal with it.
Steve V, so if understand correctly, I should be able to stand this spoiler on one end, shake it a bunch and these bit should all go to the lower end? Then I can just drill the hole and it should mostly all come out, correct??
Old 09-30-2025, 07:12 AM
steve v's Avatar
Yes, that should do it. The internal ribs were on the upper part of IIRC.
I have pictures of the spoiler in pieces but I think they're on an old computer that I've lost the password to.
