Old 10-22-2025, 10:35 AM
tekuhn tekuhn is offline
Default Swept Oil Filter Adapter?
Hello,
I'm hoping someone can tell me what it is I am looking for..... I'm familiar with the standard 90 degree and the angled oil filter adapters, but I'm pretty sure I have seen pictures of one that angles the filter rearward as well. Perhaps used with long branch exhaust manifolds?
I'm doing an installation of a RA-IV in my '63 Tempest that will require custom exhaust manifolds/headers and I think a swept oil filter might help with exhaust clearance.
If this exists, is it a complete housing, or just an adapter that sandwiches between a normal housing and the block?
Thanks for any help!
Tom Kuhn
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
Old 10-22-2025, 12:45 PM
I've since learned that there are two versions of these adapters - one for F and X bodies with long branch and one for full-size cars with long branch. It appears the F/X body version is thinner and doesn't move the housing out as far toward the frame. I was able to locate one of these and order it. I do still need to locate a straight 90 degree filter housing to use with it.
Old 10-22-2025, 12:46 PM
tom s tom s is offline
yes it is a adapter that goes between the block and your oil filter adapter.For your 63 get the first gen version.The early big car one is too thick for the tempest.Tom
Old 10-26-2025, 05:31 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Tom, can you identify this adapter?
ID:	659432   Click image for larger version
ID:	659433   Click image for larger version
ID:	659434   Click image for larger version
Old 10-26-2025, 06:38 PM
The first and last have been modified for some reason.The factory first gen used a block. With a thin plate and used 2 gaskets.The current ones just use the block.Tom
Old 10-26-2025, 07:06 PM
All of the photos are of the same part. Did SD421 engines use adapters like this?
Old 10-26-2025, 08:13 PM
I know the HO engines used it but don’t remember if the SDs did.Tom
Old 10-27-2025, 02:20 PM
turbo69bird's Avatar
The one piece is supposed to be better
But of course if you’re doing a restoration (like I am ) you need to find the 2 piece. . If anyone has one for 69bird let me know.
I hear the 2 piece is a pain and can cause issues.
I’ve had a 1 piece on my car for decades without any issues .
960 HP @ 11 psi, 9.70 at 146.
Old 10-27-2025, 07:35 PM
Idk if RARE still has them but pretty sure they had the one piece ones.
