Old 11-14-2025, 06:31 PM
1911a1 1911a1 is offline
Default engine on break in stand pic
A pic of my engine on the run in stand. Tomorrow is when we plan to start it up if everything goes to plan.
My friend who owns the stand has considerable more experience with engines and general mechanics. will be here to help.
He has been here several times during the assembly to guide and help.
The Following 2 Users Say Thank You to 1911a1 For This Useful Post:
Old 11-14-2025, 10:40 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Looks good!
Hopefully it runs like a champ!!!
Old 11-15-2025, 12:07 AM
Schurkey Schurkey is offline
You have a roller cam? Minimize your time on the run-stand. Get that thing in a vehicle, or on a dyno so the rings and cylinder walls can see some loading, and then some high-vacuum. Alternate load and vacuum to assure the rings and walls are appropriately broken-in.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 11-15-2025, 12:27 AM
Dont forget to take the rags out of the exhaust ports before you fire it up!
Old 11-15-2025, 11:42 AM
Tom Pugh Tom Pugh is offline
pull the bellhousing so you can check for rear main seal infant death failure and rear oil pan seal leaks
Old 11-15-2025, 04:35 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
It's a beauty, they never look better than when they're new
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 11-15-2025, 07:43 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Looks great! Fire that baby up!
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
