Old 11-16-2025, 09:08 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default Original Tire Choices - 1972 Formula
Working on a 1972 Formula that originally came with 14" Honeycomb wheels. However, the plans are to install a set of 15" Honeycomb wheels. What would have been the original tire choices in 1972 for 15' wheels?
Old 11-16-2025, 09:12 PM
65madgoat's Avatar
Goodyear Polyglas or Firestone Wide Oval
Old 11-16-2025, 09:15 PM
Norwood's Avatar
Norwood Norwood is offline
F60/15 for some reason I believe the Poly glas would be correct, but the repop wide oval radials look interesting
Old 11-16-2025, 09:47 PM
F60x15 on a 15x7 wheel. 235/60R15 is basically same size as the F60....
Old 11-17-2025, 10:44 AM
Yes, we have a 72 with an original Firestone wide oval f60-15
The Following 2 Users Say Thank You to Tellyshavilli For This Useful Post:
Old 11-17-2025, 10:37 PM
Formulabruce's Avatar
F70-14.. could even be black wall.
" Long may we DRIVE !"
Old 11-18-2025, 02:29 PM
unruhjonny's Avatar
Because I suspect 1970 through 1972 used the same tires, here is an original 1971 wheel and tire.
Edit: According to a superbirdclub article, this is a second week of July 1970 dated tire;
= 28th week of 1970;
It is pre-DOT with an eight character date code which starts with 'A7'
According to this chart:
A7 = 28th week of 1970; 2nd week of July 1970
Also, this is a KN wheel dated July 28 1970 - which is one of two dates that wheels with this code were made.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 11-21-2025, 08:24 PM
necdb3's Avatar
necdb3 necdb3 is offline
I believe in 72, Either Firestone or Goodyears could have been installed with F60x15. I bought a 72 Formula 455 W/ handling PKG off the original owner back in 1979. It had Wide ovals on it. At the time I worked for goodyear and asked him about the tires He said it originally came with wide ovals, It also still had the original spare.
I currently own a 72 T/A. I have the original build sheet. It shows "UDDL 5" as a tire code."UDDL" was a code that goodyear had printed in large letters on the tread of the tire. "5" was that my T/A came with 5 full size tires, no mini spare.
I can't speak for other years however, most auto manufacturers would prefer to have multiple sources for parts in case of a supply issue. I would have to imagine that would be the case but who knows.
The Following User Says Thank You to necdb3 For This Useful Post:
Old 11-23-2025, 09:10 PM
Thanks for the information everyone.
