Old 11-23-2025, 03:44 PM
jjs jjs is offline
Default HEAD LITE SWITCH KNOB PROBLEM
The light switch chrome knob came off and when I tried to put back on it would
no stay ,locked on, when I pull the to turn on the headlites on the knob comes off.
DOES ANYONE HAVE FIX FOR THIS PROBLEM.
THANK JJS
Old 11-23-2025, 04:58 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
If it's like the GTO switch the knob has a stem. It is released by having it in headlight on position while pushing the 1/4" button on the side of the switch behind the dash. To replace just push the new one in.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 11-23-2025, 11:15 PM
Is the knob pulling off of the stem?
Old 11-24-2025, 10:14 AM
burd burd is offline
Don’t pull so hard.
Prob need a ned knob
Old 12-06-2025, 01:10 PM
jjs jjs is offline
Yes how is it attached to the stem? there is a clip on the stem but the knob won't stay attached, any suggestions??
Thanks JJS
Old 12-06-2025, 09:29 PM
694.1 694.1 is offline
Epoxy.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 12-07-2025, 11:59 AM
Just get a nos one.
Old 04-15-2026, 09:38 PM
hgiv hgiv is offline
I bought a new nob but still
Didn’t help. I just glued it as suggested. Problem solved.
Old 04-16-2026, 01:46 PM
necdb3's Avatar
necdb3 necdb3 is offline
Remove the clip from the stem and install it in the plastic knob. Then push it on the stem. You're probably not getting the clip in the knob if it's still on the stem.
Old 04-22-2026, 01:22 PM
StevenK StevenK is offline
Got tired of scrapping the my hands fingers trying to press and release the stem from the light switch dimmer just to remove the dash. I drilled a small hole in the knob and put a small set screw ,made from another fine threaded screw shank. Filed a small notch in the stem for screw to sit in. works great and Case closed!
Old 07-04-2026, 02:12 PM
BTW, I bought the Ames replacement knob with stud. Seems that rod is a half inch too short resulting in parking lights stay on with knob pushed in fully!
Old 07-04-2026, 04:30 PM
Cammer-6 Cammer-6 is offline
Woops!
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
