Old 11-24-2025, 10:47 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default rack and pinion
Hi everyone,my question of the day is: What kind of rack and pinion should I get for a1969 Gto ,and do you think it is a good idea.One more thing ,one that don't break the bank?Thank you,Tim
Old 11-24-2025, 11:44 AM
JLMounce JLMounce is offline
Rack and Pinion in a stock frame A-Body is a no-go. The bumpsteer the system creates is incredibly bad. You trade some upgrade in steering feel, for much worse handling.
If you're looking to spend that kind of money, give Lee Power Steering or Turn 1 a call and have a really nice steering box built for your application. You'll get 90-95% of the steering feel you are after without degrading the handling performance of the car.
Since it seems like you're on a bit of a budget as well. I would spend the money to rebuild the entire steering system, including call joints, tie rod ends, drag link and idler arms. I'd then look at the Borgeson steering gear, which is still a budget friendly part compared to the high end Lee or Turn 1 product.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 11-25-2025, 07:37 PM
One thing that is often over looked is front end alignment. A good shop can do wonders for the way your car handles by being creative.
Old 11-27-2025, 12:24 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I second a good alignment-often factory A arms will not allow enough positive caster for good feel either.
Skip Fix
Old 11-27-2025, 01:49 PM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
As the others stated, a R&P is not really the path to go down, a well setup RB front end will perform equally well.
The biggest hurdles of the early A Body is, as another member said, getting more positive Caster in the steering.
For a daily driver with some good fun the targets are:
Alignment Specs
Camber: 0 to -1 degree
Caster: 4 to 6 degrees
Toe: 1/16” to 1/8” toe in
Moving to a Taller Spindle and upper control arms is the first step to this.
Attached is a listing of the parts that has served the Angry Old Goat well for well over 30k miles...
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
Old 12-06-2025, 01:47 PM
Default Rack and Pinion
Thanks guys for all the replies, I've decided to go with stock linkage,just having a hard time putting it together.I can't seem to get everything to go together.Have everthing out now to start over.Center link rides over front crossmember.Thanks guys i'll get it figured out sooner or later.
Tim
