Tri-Power Tech 57-66 Tri-Power Talk
Old 11-27-2025, 07:01 AM
Joe Joe is offline
Default 66 tripower floats
Which floats would be correct for the end and center carbs
thanks
Old 11-27-2025, 09:44 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
thanks
I have the 65 tripower. The single one on the right looks correct for the small base 65 center carb.
the 4 on left look to be correct for the larger base front and rear on mine.
I would imagine for 66 large base center carb would use them also.(just guessing)
Old 12-02-2025, 10:49 PM
Dick Boneske's Avatar
All large floats on '66.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-04-2025, 04:41 PM
Joe Joe is offline
Thank you both. A few days ago, I submerged all of the large floats in 140 deg. F water. No leaks. Then, just out of curiosity I placed each float on an electronic scale.
All came in at .4 oz. So, floats seem good.
Thanks again,
Old 12-05-2025, 12:13 AM
For quite a few years, I've seen many brass floats leak. I test each one by submerging in water at about 200 degrees. I scrap every one that leaks, as I have not had good success with re-soldering the seams. These floats are 60 plus years old. The aftermarket brass floats are noted to be unreliable.
Pontiac switched to nitrophyl (plastic) floats in 1968, likely for cost savings. I have found the plastic floats to be more reliable than brass.
BONESTOCK GOATS
