Old 12-01-2025, 04:40 PM
DogMeister's Avatar
DogMeister DogMeister is offline
Default Best Oil Filter Relocation Kit?
Headers in the way, as usual. '67 GTO, 1969 400 YB block.
461 Stroker Built by Me -
Old 12-01-2025, 05:13 PM
steve25 steve25 is offline
What’s best is if the motor is disassembled and you drill and tap the block for 1/2” pipe.
I believe it’s Butler who has a nice thick adapter plate that will not split and leak with the 1/2” pipe fittings .
This is the way I had to run my hoses with two 90s to clear my headers and get to the filter bracket.
ID:	661545   Click image for larger version
Old 12-01-2025, 05:43 PM
Dragncar Dragncar is offline
Canton make a nice adapter. I am pretty sure the hole in a PMD block is not far off from the drill size for 3/8" pipe. They make # 6 AN to # 10 hose fittings.
3/8 NPT tap drill is 37/64 ", not small. I would not drill it out to 1/2" pipe unless I had to. Not worth the risk.
I had that issue with headers. I ran a K&P 35 micron screen filter. Its pretty small and your headers will fit. Then I ran a Franz by pass filter to get the small stuff.
Old 12-01-2025, 06:03 PM
Since I went into block the used 1/2” pipe to end up with at least that needed 3/8” ID of the oil passages, so I did have to grind a flare into the return side passage on the block to match the ID of the 1/2” pipe.
Old 12-01-2025, 06:09 PM
JLMounce JLMounce is offline
While I don't disagree that drilling/tapping the block is the absolute best way to go, it's impractical if the engine is in good condition and already in the car.
Nitemare Performance makes an o-ringed adapter plate that should fit the bill. You can get either just the plate, or as part of a complete kit including the lines, oil filter block and mounting solution.
http://www.nitemareperformance.com/oil.html
-Jason
1969 Pontiac Firebird
The Following 2 Users Say Thank You to JLMounce For This Useful Post:
Old 12-02-2025, 03:34 AM
That Nightmare plate looks nice, but I would not use those hard 90 deg fittings that come with that kit.
Get a full flow 90 .
The Following User Says Thank You to Dragncar For This Useful Post:
Old 12-02-2025, 04:22 PM
VCho455's Avatar
VCho455 VCho455 is offline
It seems odd the kit shows one full flow 90" at the block but not at the filter. Maybe it's a bad photo in the description. I'd certainly ask about it before ordering.
Old 12-02-2025, 05:06 PM
Steve C. Steve C. is offline
Calculating the total oil capacity of your engine set up and the use of a remote mounted filter.
Keeping in mind the amount of oil inside the lines to and from the remote filter is always a good idea.
Example, my remote filter is mounted on the subframe behind right front tire. The lines have about 1/4 quart inside them.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 12-02-2025, 06:06 PM
My only real worry with these types of deals is not having that bypass. The large element filters with -10 lines should flow enough to not have any issues, but you get some crud in there, or end up with a filter that has some type of issue and you no longer have that bypass to save the engine.
Maybe I'm over thinking that though. These types of setup have been used for years and I'd like to use one to incorporate a thermostat controlled oil cooler as well. I guestimate that with a front mounted oil cooler, lines and addition of the 2 quart oil filter itself that total oil capacity would be around 8-9 quarts.
-Jason
Old 12-02-2025, 10:07 PM
Choose a location that minimizes the length and bends required for the hoses. It's often best to place the filter relatively close to the engine.
Old 12-03-2025, 05:40 AM
nas t eh nas t eh is offline
Don’t most remote filter mounts take the big Ford filters that have an internal bypass in the filter? It’s one of the best reasons to go remote. Two big good filters with built in bypass. I run a pair of Fram HP1s on mine.
73 T/A 455, 4speed
The Following User Says Thank You to nas t eh For This Useful Post:
Old 12-03-2025, 11:11 AM
I actually didn't think about that. I'd feel much more comfortable that being the case.
-Jason
Old 12-03-2025, 12:14 PM
R 70 Judge's Avatar
It depends how much you want to spend. If you want the best it would be https://clearviewfiltration.com/product/p405-filters/ or https://clearviewfiltration.com/product/p400-filters/
I have a Clear View Filtration set-up on my TA and I'm happy with it (It is either Part # 405-115-B or Part#400-115B... I can't remember). I use Wix racing filter Part#51069R or #51060R (taller filter). I'm running -12 PTFE lines but you would probably be fine with -10. The -12 are a pain in the butt to get on the block adapter.
I'm using an old Butler block adapter but I have a new Nitemare Performance adapter waiting to go on when I get around to it. The Kauffman adapter wouldn't work with the -12 lines.
At a little lower price point, Motion Raceworks makes some nice stuff. I don't have nay first hand experience with it though.
https://motionraceworks.com/products...SABEgIWL_D_BwE
ID:	661669   Click image for larger version
ID:	661670   Click image for larger version
James
1970 Trans Am
Old 12-03-2025, 12:30 PM
R 70 Judge's Avatar
For sure! There's a lot of oil stored in the big -12 lines and filter
James
1970 Trans Am
