Old 12-04-2025, 02:54 PM
MPNX2 MPNX2 is offline
Default 1966 Billing History Help
Can anyone help with decoding the following billing history? I am having trouble finding any reference to the options
Old 12-04-2025, 03:13 PM
burd burd is offline
PHS?
Old 12-04-2025, 05:37 PM
Keith Seymore's Avatar
Zone 23, Dealer 11 = Zone 23 is San Francisco zone; dealer 11 Moore Buick-Pontiac-GMC Truck, PO Box 276, Los Gatos CA
Invoice date 6/29/1966
Model 24217 = GTO 2 dr hardtop coupe
Z = Fremont assembly
KK = Reef Turquoise Metallic
220 = dark Turquoise interior
Box 34-2 = Radio Push button & Manual Antenna
Box 41-4 = Lamp, Parking Brake
Box 42-1 = Lamp underhood
Box 43-1 = Seat Belts Custom front and rear
Box 44-8 = Inst Panel rally guage cluster and tach
Box 46-1 = RPO P01 wheel disc deluxe
Box 53-2 = Glass soft ray Winshield only
Box 61-6 = Smog (per 60sstuff, below)
Box 62-1 = Ride and Handling package
Box 70- C and 71-C = 7.75x14 red stripe
Box 74-K = 3.55 axle (per 60sstuff, below)
Box 75-W and 76-W = WW engine, Man Trans with AIR, 4 bbl carb
Box 77-W = wide ratio trans
Box 78-4 = manual 4 speed
8838 and 9912 are the trunk and ignition key codes. Armed with those a locksmith can make new keys.
'63 LeMans Convertible
'63 Grand Prix
The Following 2 Users Say Thank You to Keith Seymore For This Useful Post:
Old 12-04-2025, 05:48 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Box 616 is A.I.R. (Smog).
C C is Redline tires.
K = 3.55 axle
W = wide ratio
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 12-04-2025, 05:59 PM
Originally Posted by burd View Post
PHS?
That IS the PHS. The billing history card (invoice) is what PHS decodes to create the packet.
You have to have a build sheet (or list of codes, like from the Eric White book) to decode.
Although - I'm not sure how one gets the billing history card without getting the PHS decode.
K
Name:	66 GTO buildsheet.jpg
ID:	661730   Click image for larger version
Name:	Eric Book Cover.JPG
'63 Grand Prix
Old 12-04-2025, 06:02 PM
60sstuff's Avatar
Here are two documents that pertain to a 1966 GTO.
Disregard the underlines as they pertain to my personal car.
ID:	661732   Click image for larger version
Old 12-04-2025, 07:00 PM
Great color combo ! And some good options.
Should have gotten at least one order form page like this with the BHC you have.
Old 12-04-2025, 07:09 PM
616 =
Option 612 - Air Injection Reactor (AIR) Exhaust System
Option 614 - Positive Crankcase Ventilation (PCV) System
Both required in California 1966 with manual trans, went hand-in-hand with your WW (Cali) engine code.
Air cleaner (if original) should have a pipe going from it to the valve cover.
aka closed system
Old 12-04-2025, 08:53 PM
60sstuff's Avatar
FYI to keep the information correct for 1966 GTO’s.
Automatic with 4BBL. (code XE) also required A.I.R. (Smog) if sold New in California.
The only GTO that did not require A.I.R. in ‘66 was the Automatic Tri-Power (code YR).
Old 12-04-2025, 09:32 PM
Awesome, everyone, thank you for the help! While the car was originally a 4BBL model, it now has a TriPower.
Its claimed the motor has a YF stamp on the front passenger side of the block, not sure what vintage that is , also the manifold has a 093 stamped on it. I go and inspect tomorrow.
Old 12-05-2025, 12:34 AM
I noticed your YR car only shows 614 closed vent on the BHC
No 612 air pump.
Was 614 required on Cali YR engine - or did buyers choose that option ?
Old 12-05-2025, 12:45 AM
YF could be from a lot of different years , but most likely a 65-66 389 ,
since they used 093 heads with it.
The heads are correct for 66 GTO , the manifolds start further below the 093 casting number.
389 block will have 3 freeze plugs per side.
Old 12-05-2025, 12:56 AM
On Keith's 66 Buildsheet they call it
612 Exhaust Control
614 Crankcase Vent
Exhaust control must be a GM blanket term , like with Chevy and their fancy plumbing into the exhaust ports.
Great condition on that Buildsheet , Keith !
Old 12-05-2025, 07:59 AM
Singleton Singleton is offline
2 per side, right?
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following 2 Users Say Thank You to Singleton For This Useful Post:
Old 12-05-2025, 08:31 AM
Originally Posted by Singleton View Post
2 per side, right?
Yes , and thank you.
Not sure how I crossed that up .
Photo memory needs a new roll of film in it.
Old 12-05-2025, 10:44 AM
WQ59B WQ59B is offline
I list Moore as 23 011 in the '90s. For '67, 23 011 was Bernie Anderson Pontiac-Buick in Eureka CA.
The Following 2 Users Say Thank You to WQ59B For This Useful Post:
Old 12-06-2025, 12:27 PM
Thank you for all the help. I do have the accompanying PHS documents now it all makes sense.
Picked up the car yesterday after a very long day.
Ill make another post with pictures once I get it unloaded.
ID:	661789   Click image for larger version
Name:	66 gto P2.jpg
The Following User Says Thank You to MPNX2 For This Useful Post:
Old 12-06-2025, 01:23 PM
We should let John Wallace (wallaceracing.com) know. Do you have a PHS, build sheet or invoice for documentation?
23-011 does not appear on the UltimateGTO dealer code list.
K
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 12-06-2025, 01:36 PM
K
Keith, if you are referring to me yes, I have the full PHS documents. I have some documents with the car that I still have to go through.
Old 12-06-2025, 01:51 PM
No - I was referring to WQ59B.
You will likely not have the dealer name unless you have the original window sticker or purchased a reproduction from PHS.
K
'63 Grand Prix
