Old 12-04-2025, 11:53 PM
twilightTA's Avatar
twilightTA twilightTA is offline
Default How to remove wiper blades
How do you pop off the wiper blade from the arm on a 77 Trans Am? Just picked up some new blades. Attached a pic of the blade.
-Darryl
1977 Trans Am restomod with E-Rod LS3 and 4L70E.
Old 12-05-2025, 10:34 AM
78w72 78w72 is offline
Get a thin flat blade screw driver and wedge it in between the blade and arm, a little twist or pry will pop it out. Its a press fit.
Old 12-05-2025, 11:32 AM
twilightTA's Avatar
Thank you
-Darryl
The Following User Says Thank You to twilightTA For This Useful Post:
Old 12-05-2025, 11:56 AM
propuckstopper propuckstopper is offline
You might want to shoot a little penetrating oil in there as well. It looks a bit corroded, although my old eyes might be deceiving me!
Old 12-05-2025, 12:47 PM
ta6point6's Avatar
lift one side of arm up and then push in the middle, spring tension keeps those originals on
going bandit-Reynolds style
Old 12-05-2025, 08:51 PM
twilightTA's Avatar
Thanks all - successfully replaced them. Pretty easy.
-Darryl
Old 12-06-2025, 12:39 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Many of the replacement arms are to tall to retract under the hood.
Skip Fix
