Old 12-17-2025, 04:05 PM
Kirill Catalina Kirill Catalina is offline
Default Wiring from org. starter to mini starter Pontiac 400
Hi all,
I'm currently swapping the old starter for a Load Boss mini starter. I'm having a question about the wiring. Both have the big connection for main power from the battery but the mini starter only has 1 smaller connection. Which has to be the trigger wire.
So, I put the 2 big cables on the bigger connector. The small red wire on the trigger connection but where does the brown, most left small wire go and what does it do?
Also, there's a small cable coming from the blue plastic wrap thingie on the mini starter.. Anyone knows what that's for?
ID:	662301   Click image for larger version
Old 12-17-2025, 06:53 PM
Bill Hanlon's Avatar
The "left small wire" is the circuit that bypasses the "ballast resistor" between 12v "ign" and coil + when the starter is engaged. Unless you are using points-type ignition, you don't need either the ballast resistor or the bypass circuit.
Old 12-19-2025, 07:42 AM
Thanks! Taped off the extra wire and hooked up the other ones. Works like a charm
Old 12-19-2025, 11:08 AM
george kujanski's Avatar
Just asking...is your car a Firebird?
George
