EFI Tech All things EFI and making classics modern!
Old 12-29-2025, 05:58 PM
Speargun's Avatar
Speargun Speargun is offline
Default MAT/IAT Placement Terminator X
I'm installing a Terminator X in my Firebird and wanted to get your opinion on where to place the MAT sensor.
I'm going to run a 90* at the manifold and a 102mm LS style throttle body. I know that in front of the TB would be best, but I don't have that option until I set up a cold air system.
I'm thinking in the back of the 90, a couple of inches above where it bolts to the intake (firewall side). What do you think?
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 12-30-2025, 04:48 AM
krisr's Avatar
krisr krisr is offline
That's where I welded a bung on my adapter and put my air temp sensor. Just note that it'll be subject to heat soak but you can account for that in the tune using air temp corrections.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 12-30-2025, 03:35 PM
R 70 Judge's Avatar
Mine is in the back of my intake elbow. It’s next to the remote IAC.
ID:	662908   Click image for larger version
James
1970 Trans Am
Old 02-02-2026, 02:18 PM
HWYSTR455's Avatar
I did mine on the front, bottom of my elbow, but really, it can go just about anywhere.
IMO closer to the intake it is the better, but that's just my way of thinking, I have no tech info to support that.
