Old 01-05-2026, 06:04 AM
Squidward's Avatar
Default Big hole in carb bracket?
The big hole, about 1/2" diameter, in a Holley carb throttle shaft bracket...
Is this big hole used often, or ever, for the throttle linkage? Is there a bushing that goes there for a rod system?
I ask because I am exploring options on where to attach my throttle rod. I tried converting my 67 Firebird from stock rod setup to a cable, and was unhappy. Now I am going back to stock-ish. My FiTech has a big hole, and a small hole on the bracket. The small hole requires a lot of pedal pressure because it is a closer radius to the throttle shaft. The big hole is farther away.
Anybody out there using that hole, and how did you do it? Thanks.
Old 01-05-2026, 06:20 AM
carbking's Avatar
carbking carbking is offline
Chevrolet linkage uses the large hole. There is a rubber bushing that fits the hole, with a nylon bushing inside the rubber bushing.
Jon
Old 01-05-2026, 08:50 AM
grivera's Avatar
grivera grivera is offline
Some throttle brackets use the hole for a front mounted return spring. I have one in my 66.
Will Rivera
Old 01-05-2026, 01:00 PM
HWYSTR455's Avatar
Holley used to make a kit that had all the hardware, but forget what the were called. I think they broke it down into several kits bc of the cost of the all inclusive kits.
https://www.holley.com/products/fuel...arts/13-103QFT
Some cars/truck had solid rod-type linkage, and those I believe also used that attachment point. Cars that needed max travel I guess.
Old 01-05-2026, 01:23 PM
chiphead's Avatar
chiphead chiphead is offline
Used for a no-bind return spring mount. This is how the 4150 came set up on the '67 LeMans I bought. I like it once I got used to how it works.
https://www.ebay.com/itm/331175285508
https://cnc-motorsports.com/catalog/...-bracket-blue/
Old 01-05-2026, 02:36 PM
Squidward's Avatar
Jon
Ok, was wondering why there would be 2 bushings sold in a group. Searched on 67 Camaro.
I definitely needed the rear bushing, didn't know there was a front bushing setup. Says the grommet/bushing is for many GM applications back to the 50's
Old 01-05-2026, 03:10 PM
Kenth's Avatar
Kenth Kenth is offline
These are the grommet and bushing for the Chevy/Olds throttle lever:
Name:	Throttle Lever Grommet.png
ID:	663172   Click image for larger version
Name:	Throttle Lever Bushing.png
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 01-05-2026, 04:34 PM
Squidward's Avatar
Thanks, got one coming.
I just stopped at a local Ace hardware store and found a few nylon bushings and spacers that might work, too.
Old 01-05-2026, 05:20 PM
HWYSTR455's Avatar
Overview from the actual item on the Holley website:
Overview
Throttle Lever Bushing & Grommet
Features:
Replaces worn out bushings to enhance throttle feel
Old 01-07-2026, 03:12 PM
Squidward's Avatar
I DID find grommet and nylon bushing parts that fit my gas pedal lever hole, with a little shaping. The same grommet that fits back there fits the big hole.
I measured the distance of a qjet throttle stud from the shaft, and it was a 1.5" radius. There is a hole on my fitech that was in the same place, but too small. So I drilled it out to 1/4" so the rod would fit, and success!
I now have an OER grommet/bushing as a spare.
Throttle movement is now silky awesome, and gets full travel. Sometimes, impatience can be a benefit.
