Old 01-06-2026, 04:16 PM
John Milner's Avatar
John Milner John Milner is online now
Default Dash Speaker
I have a Delco am/fm mono radio and console mounted 8 track player for my 71 GTO and I am going to need to replace the front dash speaker. I have a nos speaker but it has 2 wires coming from it instead of just 1 like the factory speaker. My original speaker has a plug coming from the 1 wire and that plugs into the back of my radio. The new speaker has the harness in the picture that plugs on to the 2 prongs coming from the speaker. I am assuming one wire will take the place of the wire that goes to my radio and the other may be a ground? Am I correct?
ID:	663236   Click image for larger version
ID:	663237   Click image for larger version
Old 01-10-2026, 03:38 PM
Just to follow up in case anyone else has this question, one has to be grounded.
The Following User Says Thank You to John Milner For This Useful Post:
Old 01-10-2026, 07:11 PM
indymanjoe's Avatar
John,i just pulled my dash and i have only one wire to that speaker. the speaker has 2 terminals. Mono 1 speaker factory am/fm factory replacement speaker with no ground. i wonder why mine isnt supposed to be grounded? it still works just fine.
I am the Thread Killer!
Old 01-10-2026, 07:56 PM
Held for Ransom's Avatar
OE were grounded to the frame of speaker (look closely at the wires coming from the cone to the connection). I had to ground one side and made a replacement for the radio when I replaced with a S&M Electro Tech Unfortunately, Firebird is shaped backwards to the repro. wiring and I had to add a little length to that wire.
So long, farewell.
Old 01-10-2026, 08:11 PM
indymanjoe's Avatar
Yep, just looked closer, and it's grounded to the frame. and that's the replacement i got S&M Electro Tech. Thank you for clarifying.
