Old 01-21-2026, 08:10 AM
lew4ut lew4ut is offline
Default PHS question for 68
I have a friend that has a 1968 GTO convertible and has received the PHS documentation for this Baltimore built GTO. For some reason the engine id and the transmission id both are showing all zeros in both locations. Has anyone ever seen this before and if so what would the explanation be for this?
RG
Old 01-21-2026, 09:34 AM
Beers Beers is offline
The trans field is blank and the engine number is all zeros on the PHS-provided billing card for my Framingham-built ‘68 GTO. Didn’t think these two fields were used anymore on the billing history by ‘68.
1968 GTO Aegena Blue
Previous: 1970 Firebird Formula 400, 1964 Catalina, 1968 Firebird, 1967 Firebird 400 conv
Old 01-21-2026, 11:43 AM
johnta1 johnta1 is online now
I know the Firebird in Lordstown had them. Possibly the non-full Pontiac plants did that? (combined chevy and Pontiac plants)
Well, checked a couple Pontiac and Fremont had them. Maybe just Baltimore and Arlington?
Old 01-21-2026, 11:53 AM
ts3189's Avatar
ts3189 ts3189 is offline
On my Kansas City built 68, the bhs for engine number and transmission number are blank.
Old 01-21-2026, 11:56 AM
DANTIP DANTIP is offline
Default 68
I know 1968 was the first year for engine partial VIN stamps, therefore, the EUN wouldn't be needed??
ts3189's Avatar
My Kansas City built 68 Gto has blanks for both engine and transmission.
Old 01-21-2026, 04:02 PM
Default Thanks for your response
Thanks to all for your response I am guessing that because the serial numbers were stamped on the engine block pad that they did not do them.
Thanks again
RG
Old 01-21-2026, 07:00 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
My 68 GTO was born 11/22/67 in Pontiac Mich, and my paper work has the ID. numbers for my car.
color me gone
Old 01-21-2026, 07:06 PM
OG68 OG68 is offline
My Fremont 68 didn't have the EUN or trans ID. Just blank spaces
Old 01-22-2026, 10:09 AM
What's the body date?
I checked about all I have and this is what I found:
Baltimore had EUN printed thru Oct 1967 after seemed to be zero's
Pontiac had them
Lordstown had them
Arlington had them
Fremont had them ; Some had partial EUN with leading engine code (except OG68 above)
Baltimore did not after Oct 67
Van Nuys did not
Kansas (K) did not
Canada did not
Framingham did not (didn't have many of these)
Old 01-22-2026, 03:04 PM
05A.
Invoice date May 7, 1968
Old 01-22-2026, 06:38 PM
I guess there is always one in the bunch.
I have one on each side of that date with the EUN.
Probably around 64xxxx EUN.
HD 3 speed on the floor?
Old 01-22-2026, 10:15 PM
Yep. The only options were;
AM Radio
Remote Mirror
Goodyear Radial Tires (205R14)
Old 02-09-2026, 04:32 PM
Cicerogue's Avatar
Cicerogue Cicerogue is offline
I have PHS documents for two Framingham built cars. One is a Feb. 1968 built '68 car that has all zeros for the engine unit number and blank for transmission unit. The other is an Oct. 1968 built '69 car. The engine unit number on the billing history matches the last four digits stamped on the block below the head plus the engine code (YS) and the transmission unit number is blank.
The Following User Says Thank You to Cicerogue For This Useful Post:
Old 02-11-2026, 12:57 AM
Dawbs Dawbs is offline
My 68 Fremont built Oct 1967 has both engine and trans numbers on the billing sheet.
The Following User Says Thank You to Dawbs For This Useful Post:
Old 02-12-2026, 09:35 PM
grandam1979 grandam1979 is offline
Just checked my 68 Firebird it has the engine numbers but trans is blank.
The Following User Says Thank You to grandam1979 For This Useful Post:
