Old 01-24-2026, 11:00 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Default Most Basic Setup
Is this the most basic turbo setup:
Logs
Single Turbo
Blow Through
With or without A2A
Manual boost controller
How do you control timing?
Thanks.
Old 01-25-2026, 08:50 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
You could Do it w an msd timing retard or a digital 6/7 or a grid or efi from
Cheapest to most expensive
Old 01-25-2026, 11:36 AM
ponjohn's Avatar
Just use a boost reference?
The Following User Says Thank You to ponjohn For This Useful Post:
Old 01-25-2026, 09:00 PM
R 70 Judge's Avatar
If you want basic and affordable go with Richard Holdener’s stuff. Single turbo will definitely be cheaper than twins. His G42-1200 billet wheel turbo would probably work great on a 400/428
https://richardholdenerperformance.c...and-components
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 01-27-2026, 11:35 AM
budget wise, you would have to do it by rpm determining how much boost you are making at each interval. i think you would need an input to do it referencing boost and none of those listed are going to be dynamic.
Holley terminator EFI is a great set up with plenty of room to grow. its not cheap but neither is a grenaded motor
Old 01-28-2026, 08:19 AM
charlie66's Avatar
Logs
Single Turbo
Blow Through
With or without A2A
Thanks.
Yes, it is
Nothing is cheap these days but for timing control it would be cheapest with a BTM box..
You can find them used if you get lucky.
Run your WG spring and if you want more down the track you can get a solenoid to get more power with your manual knob controller. I don't like the bleed off knobs. Get the one from Treadstone performance where it adds psi to the top of the gate its more stable.
My Half AN Injun.....
Old 01-28-2026, 08:30 AM
67Lemons 67Lemons is offline
A single turbo set up would be great for the street, too bad it still requires a lot of fabrication work for Pontiac engines vs the plug and play offerings for Chevy and Ford small blocks.
1972 GTO
Old 01-28-2026, 06:59 PM
RocktimusPryme's Avatar
Doesnt progression ignition have the ability to tube timing for boost? While I wouldnt call them cheap, they are reasonable compared to a seperate ignition box when you consider you have to spend money on a distributor anyway.
Old 01-28-2026, 07:35 PM
ponjohn's Avatar
Instead of alcohol ( washer fluid) can you spray E85?
