My steering wheel column on my 77 lemans is very wiggly. I'm going to have the steering wheel off to change the key, and I was just wondering which bushing could be causing this. The tilt is locked and it still rocks. Thanks Andrew
The 4 bolts deep in the column are probably loose. You have to go deeper than just the key. A little time consuming but easy just sitting in the driver seat.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
x2.
My 70 El Camino and 77 Chevy pickup both had that problem. Open up the column and tighten the screws.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
I agree and I always use red loctite on the 4 little screws
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
| The Following User Says Thank You to camerjeff For This Useful Post: | ||
You mean for the turn single switch? All I need to do is get the lock plate off and I'm in there. What else needs to be done? I figured I get this done while replacing the key.
Also any good hints on how to get the snap ring to the lock plate off i have the tool that compresses the plate. |
Long thin blade screwdriver for the snap ring. Pry up between ring and column housing.
You need to pull the signal switch up and out of the way to access the four hex headed screws that hold the bearing housing.
| The Following User Says Thank You to OG68 For This Useful Post: | ||
Okay I'll definitely take a look when I get the lock plate off
https://www.summitracing.com/parts/wmr-w80649 I have a couple of them and they do make the job easier. But not absolutely needed.
Sorry ment screws I'm going to throw everything back together except for putting in the lock plate. An look into fixing it later.
Update she needs a column simple as that
