Old 01-28-2026, 11:49 PM
CROCIE JR's Avatar
CROCIE JR CROCIE JR is offline
Question What is this part?
I was removing the steering column out of a customers 67' Goat. Was cleaning up and saw this on the floor mat. Was found with the nyloc half engaged as you see it. I think it fell out out of the dash at some point
ID:	664337   Click image for larger version
Old 01-29-2026, 12:32 AM
GtoFM's Avatar
GtoFM GtoFM is offline
It's part of the manual shifter. It's called the Hurst Shifter Bridge Plate. Probably left over from a shifter rebuild as it comes in the kit.
The Following 2 Users Say Thank You to GtoFM For This Useful Post:
Old 01-29-2026, 01:02 AM
dataway's Avatar
dataway dataway is offline
I was going to guess it's a Fleam Stretcher.
Old 01-29-2026, 10:37 AM
Bill Hanlon's Avatar
Can't be. Fleam Stretchers have left hand thread.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 01-29-2026, 10:58 AM
CROCIE JR's Avatar
Thank you GTOfm.
I had helpers the day we removed the engine and trans together. That piece was pulled to remove the shifter and left on the carpet under the column. I didn't see the part before I removed the column. And was like WTF is this. Mystery solved!
