Tri-Power Tech 57-66 Tri-Power Talk
Old 02-04-2026, 05:43 PM
Terry M. Hunt Terry M. Hunt is offline
Default ID this carb 2.0
You guys did such a great job on my first request to ID a carb, I decided to let you show off again.
Pics attached
Only numbers I can find on this one are on the bowl:
7008598 on the bottom of the bowl
C-3 on the throttle arm side of the bowl
Any guesses?
ID:	664627   Click image for larger version
ID:	664628   Click image for larger version
ID:	664630   Click image for larger version
ID:	664631   Click image for larger version
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 02-05-2026, 08:23 AM
Kenth's Avatar
Kenth Kenth is offline
1958-63 Chevy 283.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-05-2026, 05:26 PM
unruhjonny's Avatar
each piece should have a casting number;
A casting number is cast into the part - as opposed to application numbers being roll stamped onto a part of the assembly.
I believe all early (pre-1968) carbs had tags instead of stamped application numbers.
I am not too sure if the 2bbl carbs had a tag attached to a main body screw or not - but I believe that's how I've seen most.
People really in the know will be able to place with in a window of time based on the casting number(s) - as GM assigned them sequentially.
1970 Formula 400
Old 02-10-2026, 11:39 PM
Many thanks for your responses
Terry Hunt
Old 02-17-2026, 04:23 PM
Dick Boneske's Avatar
It's a SBC carb with the wrong throttle arm, wrong choke heat provision, broken air horn web, and smaller venturi's than the Pontiac early center carbs ('59-'65). I would trash it and find a suitable Pontiac carb. I have many if you're interested.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-18-2026, 06:16 AM
Kenth's Avatar
It's a SBC carb and as such it has the CORRECT throttle arm, and choke heat provision.
I´m sure some Chevy enthusiast would love to have it.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-18-2026, 05:09 PM
Yes, I knew it was not the correct carb for the Tripower set up it was on. Not trying to make this a functioning unit right now. Just doing an inventory on a bunch of stuff I’ve acquired over many years. I agree it might be useful to a Chevy enthusiast, so that’s probably where it will wind up.
Terry Hunt
