Old 02-05-2026, 12:30 PM
66_Cat_Jon 66_Cat_Jon is offline
Default Screw-in stud conversion
My 1966 092 heads have been drilled and helicoiled for 7/16 screw-in rocker studs. when I install the studs do I just apply oil to the threads, or do they intrude into coolant passages and need sealant or pipe dope on the threads?
Philosophy on Life: Try not to be an A**hole.
Old 02-05-2026, 01:40 PM
Should not go into coolant passages. Maybe locktite it?
Are they shouldered studs or straight?
Old 02-05-2026, 02:17 PM
Straight 7/16 top and bottom to allow adjustable rockers. The reason I mention motor oil is because the Butler torque specs list calls for it, although that's referring to heads with screw-in studs originally.
Old 02-05-2026, 04:57 PM
Later factory ones were shouldered, so basically tightening on the base. With a straight stud it would be bottoming or end of threads stopping it?
Anyway the studs will probably be a good improvement.
Old 02-05-2026, 08:28 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I can't remember for sure, but it seems like I've used thin lock nuts at the bottom of straight studs in some cases.
Old 02-05-2026, 09:20 PM
jww jww is offline
Use sealer on the threads or it will suck oil down past the threads and smoke.
Ask me how I know!!
The Following User Says Thank You to jww For This Useful Post:
Old 02-06-2026, 08:59 AM
My mistake, when you asked if the studs were shouldered I thought you were referring to the "bottleneck" area like on the non-adjustable studs. The rocker studs I'm using have the top and bottom separated by the enlarged hex portion, so shouldered as you call them.
The Following User Says Thank You to 66_Cat_Jon For This Useful Post:
Old 02-06-2026, 12:43 PM
In order to use that type of stud you need to cut down the stud bosses by about .250”. You will also need to install 7/16-14 Helicoil inserts in the stud bosses.
There’s a few pictures of the machine work done on my 1964 421 HO heads to convert them to screw-in studs in this post:
https://forums.maxperformanceinc.com...7&postcount=78
Old 02-06-2026, 02:16 PM
The machine work is already done. The studs were left uninstalled because they will have pushrod guides under them that have to be adjusted once the heads are on the engine and then the studs will be torqued to hold themselves and the guides in place. The question is, at that time do the bottom threads of the studs require any kind of sealant?
Old 02-07-2026, 06:53 PM
No sealant.
They don’t break through into the intake port, unless someone made a big mistake during the installation of the Helicoils.
