Old 02-13-2026, 10:25 PM
ChiefCrazyCanuck ChiefCrazyCanuck is offline
Default Two More Engines Dyno Tested - Pleasing Results
Hello PY'ers.
I had a good week testing two of my engines on the dyno. One is for myself to install in a 1974 Formula 455, the other is for my friend for his 1964 Tri-Power 4 speed GTO. Thought to share the information for the enthusiasts and builders out there.
Formula engine..
455 based (465 ci) 485428 block. .040 over. 24.5 CC dish Butler/Ross pistons. Eagle 6.625 rods. 103 Crank. Dan Barton 70 CC early RP Edelbrocks 2.200/1.650 valves. 10.2:1 CR. Old Faithful V1 cam. HS 1.65 rockers. Comp 857 HR lifters. Port matched KRE Northwind, BG 850 downleg Mighty Demon, Hooker 4202. 91 octane. 600HP at 5800 and 590 TQ at 4900-5000.
GTO engine..
455 based (467 ci). 485428 block. .030 over. 6cc relief Butler/Ross pistons. Eagle 6.800 rods. Eagle cast steel 4.250 Crank. My hand ported 87 CC RP Edelbrocks 2.110/1.660 valves. 10.4:1 CR. Butler HR 230/236 112 LSA cam. Scorpion 1.65 endurance rockers. Lunati (Morel) HR lifters. KRE Trade-Wind w/ 3 2BBL Holleys. Hooker 4202. 91 octane. 545 HP at 5600-5700 and 550 TQ at 4300.
I think they turned out great, ran like champions with no leaks or issues to speak of. Lots of interesting discoveries along the way as always. Ask away if any interest.
Last attachment shows overlay of the 4 engines tested over the last year. All of them turned out really well, and shows how easy it is to make respectable power out of this venerable engine.
ID:	664979   Click image for larger version
ID:	664980   Click image for larger version
ID:	664981   Click image for larger version
ID:	664982   Click image for larger version
The Following 5 Users Say Thank You to ChiefCrazyCanuck For This Useful Post:
Old 02-14-2026, 10:58 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Knocking them out! Very nice builds and results!
Keep up the good work!
Go fast, see Elvis!
Old 02-14-2026, 11:39 AM
mgarblik mgarblik is offline
Very nice engines and results. Excellent torque numbers and the power is where it can be used all the time in a street car. First results I have seen on the KRE intake with tri-power.
Old 02-14-2026, 11:50 AM
Thanks Paul!
The Following User Says Thank You to ChiefCrazyCanuck For This Useful Post:
Old 02-14-2026, 11:51 AM
Thank you sir! The Trade-Wind is a cool part that backs up it's looks with performance.
Old 02-14-2026, 11:59 AM
Stan Weiss's Avatar
Very nice results. I have added them both to the Pontiac N/A Pump Gas List in the Dyno Engine Section
Stan
Pontiac Pump Gas List
Old 02-14-2026, 12:39 PM
Stan
Cool, thank you Stan!
Old 02-14-2026, 12:41 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Really nice builds, congrats. I'm real interested in track results if you guys go.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 02-14-2026, 04:00 PM
Thank you, I do plan to run my Formula but it will be a way off. Will report back when it takes place.
Old 02-14-2026, 04:56 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Impressive numbers. Good job
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-14-2026, 08:59 PM
Thank you sir!
Old 02-15-2026, 07:59 AM
chuckies76ta's Avatar
Very nice Travis. The Formula engine did a bit better than my KRE D port heads. I run the Torker 2 with road paver 246/252 with 1.5 Rockers. 589 hp/600 T. I'm running Crower solid rollers on that cam.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 02-15-2026, 01:48 PM
Thanks Charles, and good to see how fast you all are running now with the '68!
Old 02-15-2026, 04:14 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Great results.
What do you think the heads flowed on the 465?
Old 02-15-2026, 05:20 PM
Originally Posted by ponjohn View Post
Great results.
Good question! 336 at .500 and flat from there on up. That flow level at a moderate valve lift without a gigantic port all add up.
The bigger intake valve (2.200), and the port work/valve job, contributed to the extra power output I am sure vs. the engines I had tested earlier. There were many great takeaways from these builds.
Old 02-16-2026, 12:15 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Travis, Impressive numbers. Good job
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 02-16-2026, 01:51 PM
Thanks Jim.
Old 02-18-2026, 11:38 AM
Tom Pugh Tom Pugh is offline
what do think the numbers would be on the 455 built for the GTO if run through ram air exhaust vs headers?
Old 02-20-2026, 11:28 PM
Hi Tom.
I would say down around 30 HP. And for the average guy driving it around you would never know the difference. Assuming an aftermarket RA exhaust casting with the big exit.
Just my guess. Of equal importance is the exhaust system behind the manifold or header.
We drive these things.
Old 02-25-2026, 01:59 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Nice that 465ci made some HP damn, 336cfm @.500 is nice, Old Faithful V1 cam = 236 / 242 cam?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
