Old 02-21-2026, 08:09 PM
Terry M. Hunt Terry M. Hunt is offline
Default Spatter paint on trunk brace
Attached photo shows one of the two trunk braces on my 66 GTO. Would these typically be sprayed with spatter paint? Would the entire brace be covered, only part of the brace, can somebody post a photo of how this should look?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 02-22-2026, 03:47 AM
SR-71 SR-71 is offline
This is from a 20,000 mile survivor 1966 GTO Pontiac build. As you can see the tail light bezels were installed and not the housings when the Zolatone paint was sprayed on. There was a mask to keep the paint from coming through the bezels. In case you're looking the correct part number for the Zolatone is ZT-20-TS02-QT Black/Aqua.
ID:	665304   Click image for larger version
ID:	665305   Click image for larger version
Old 02-22-2026, 04:04 AM
Here's shot of the right side of the trunk too.
Old 02-22-2026, 11:32 AM
Can’t see the face of the brace very well, but from the look of everything surrounding it it appears the brace gets completely covered; top to bottom. Correct?
Terry Hunt
Old 02-22-2026, 03:30 PM
Here's a view of another 25,000 mile 66 GTO survivor taillight panel brace. As you can see the factory workers weren't using a template or mask on these areas so they are a little inconsistent. And another.
ID:	665322   Click image for larger version
Old 02-22-2026, 03:58 PM
I figured this would not be something done with great precision and your photos bear that out. Thanks for your help.
Terry Hunt
Old 02-22-2026, 05:45 PM
You're welcome.
Old 02-23-2026, 06:18 AM
Jeff Hamlin's Avatar
Definitely no continuous consistency with a rapid-fire spray gun application moving down a moving line.
I would say no two are the same, close but not exact. Look at the inconstant specks in this spray out, and this is original.
Old 02-23-2026, 03:49 PM
All these photos are very helpful and will help me achieve a factory look when I spray my trunk.
Terry Hunt
Old 02-27-2026, 11:21 PM
400 4spd.'s Avatar
What Jeff posted is typical. Because the spatter paint has VERY poor hiding abilities, spray black epoxy primer over your red oxide primer a few days prior to your spatter paint.
Old 02-28-2026, 09:57 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Pics
ID:	665626   Click image for larger version
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 02-28-2026, 02:21 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
You'll find that these patterns vary by plant. Here's a good example of a Pontiac Plant car.
ID:	665643   Click image for larger version
ID:	665644   Click image for larger version
Old 03-01-2026, 12:40 PM
428ho4spd's Avatar
This '66 received no spatter paint on the braces. Built at the Kansas City Plant.
ID:	665688   Click image for larger version
ID:	665689   Click image for larger version
ID:	665690   Click image for larger version
ID:	665691   Click image for larger version
