Old 02-25-2026, 09:13 AM
55Wagon 55Wagon is offline
Default 57 3 speed trans swap
Hello, I am thinking about swapping out a 57 3 speed standard trans, with a later 3 or 4 speed are the bolt patterns the same for both? I only have knowledge of late 60s Bell housing. Thanks
Old 02-26-2026, 12:51 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
No, you need a 58-60 bellhousing. 58 & 59 have provisions for rear engine mounts, although the mount details are somewhat unlike the 57 mounts,
Truth is, I once did modify a '57 housing to the later trans pattern. But it was a nasty job and an ugly result!
Old 02-26-2026, 08:05 PM
694.1 694.1 is offline
That's what I was thinking. Thanks for checking in.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-07-2026, 05:19 PM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
As Jack said, you need a 58-60 bell housing. You also need a 56 (Strato-Flight Hydramatic only) or 57 Hydramatic cross member for attaching motor mounts. The motor mounts can be quite easily adapted from the bell housing to that cross member.
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
